Break pipes
One of my break pipes has corroded in two places, would it be better to change the whole pipe or just the two corroded areas?
Probably easiest to make a whole pipe as you'll only have to flare 2 unions not 4 and it can all be done off the car.
BRAKE!
and replace the complete line if its corroded
Depends on the line and the place of the corrosion, but normally I'd do the whole line at least you'll be safer then trusting a line that's corroded once
  Fitting A New Break Servo TommiePuglet 19 13,215 05-10-2017, 12:19 PM
Last Post: TommiePuglet
  break pads ashkid 4 3,008 28-07-2013, 05:51 PM
Last Post: Toms306
  Break wear sensors Toast 4 3,348 19-05-2013, 05:15 PM
Last Post: Connor
