New Pug Owner
Hi all!
Just thought I'd intro meself ere'
I picked up my first pug yesterday...
306 Meridian Estate 2.0 HDi (W Plate)
The mileage is high, but the service history, body condition and mech's all sound (Well as good as you can expect for 180k) and look good. In fact I have yet to find a spot of rust on her!
I normally run a Legnum VR4, the same type as PugMe on here as well.
Over the last five month's I've run a Mazda 323f, Merc 250TD.
Now I have had in the past the citroen version of this lump in a C5
I'll get some pics up as soon as.
Now Im sure that I'll have some standard Q's later on like...
How the F*CK do you change the oil filter? but yeah different thread!
But anyway as previously stated.
Hi all
welcome.
oil filter:
slide oil catch tray under engine.
undo oil filter....may need oil filter strap/wrench if tight
remove oil filter
(30-10-2013, 07:07 AM)Piggy Wrote: welcome.
oil filter:
remove oil filter
Yeah very funny!!!
I meant how do you get to it? Do you have to remove the header tank or from underneath?
Welcome along. You'll find lots of helpful people here if you are nice and easy to get along with Wink
Welcome.
Jack it up and go from underneath . Still a PITA to get at though i find ripping out the air con helps lol
Its pretty easy n obvious to be honest...
I like servicing hdis n xuds coz the oil filte is so easy to get to...
unlike a LOT of othet cars
Its right on the front of the block isn't it?
Does remind me though, thats something else i REALLY need to get round to. Dodgy
Welcome along BTW. Big Grin
Then header tank you can just pull it out the way. I always find smashing a screw driver through it is much easier than using strap wrench. But yeah its fairly easy just abit tight.
The dturbo I had for a bit was just as easy apart from it had seized on and snapped my screw driver Undecided
Welcome to the club though get some pictures up.
Welcome
Welcome
A screw driver isnt as good for putting the new filter on tho kent. Tends to be abit leaky
should never needa tool to refit the oil filter...hand tight only
Na i always crank it with abit of rope now. Had two oil filters on two cars leak doing them hand tight.
(31-10-2013, 06:49 AM)puglove Wrote: A screw driver isnt as good for putting the new filter on tho kent. Tends to be abit leaky
Well clearly not Rolleyes
(30-10-2013, 01:21 PM)puglove Wrote: Welcome.
This!! Mine had no air con, still not tons of room but enough to get at from above!
Welcome anyway Smile
Welcome - i've 1.4 so my experiences with oil filters won't be of much use to you...
Welcome to the forum Hello
welcome! Ive got an estate too and they seem to be becoming more popular over the past year! Have fun!
Welcome!
  GTI-6 owner soon to be d-turbo owner instead LukeC88 36 24,898 01-01-2013, 11:22 PM
Last Post: Jonny b
