aux belt
Right im in the middle of an engine conversion but the new new engine hasn't got aircon has anyone got a part number for a non aircon aux belt?
thanks jack
on my ph1 setup i found the older PAS has a larger pulley and uses - 6PK1145
and the other (newer style?) PAS pump uses - 6PK1130
the 6PK1145 will work on both but your at the end of adjustment as the belt is just that bit too long.
Are they the only 3 part numbers for Aux-belts?
My car runs a Zantia engine, so I've no idea what belt I need.
Think it used to run AC, but no longer does and still has the auto-adjusting tensioners.
Exclamation Belt slapping wildly - belt tensioned - pics added ginge191 57 50,400 25-04-2013, 09:22 AM
Last Post: Mattcheese31
