Think my front shocks are fooked...
No visible leaking around the rod or the rubber sock inside the spring, but on top of the shocks has got oil around them and in the recess. The damping on them still seems alright, and it doesnt bounce when you push it down and release it again. Any ideas why its there? popped reservoir or something?
[Image: IMG_19501_zps772b5b34.jpg]
[Image: IMG_19481_zps0c51d8f1.jpg]
That won't be oil or anything up there. Give thm a clean up and keep an eye on then
(27-10-2013, 02:13 PM)Grant Wrote: That won't be oil or anything up there. Give thm a clean up and keep an eye on then
It's definitely oil of some sort... I'll clean them up and keep an eye on them anyway, cheers
Wont be from the shocks, if they were leaking, theyd just drip down the body of the shock
(27-10-2013, 03:06 PM)Connor Wrote: Wont be from the shocks, if they were leaking, theyd just drip down the body of the shock
Hmm odd!... I popped the sump te other day but the underside of the bonnet and top of the engine aren't covered In oil, it's just the top mounts..
Not if the shafts are gun drilled, if the upper o-ring is f*cked they would leak into there.
What shocks are they?
(27-10-2013, 03:46 PM)Rippthrough Wrote: Not if the shafts are gun drilled, if the upper o-ring is f*cked they would leak into there.
Just standard as far as I know, any part numbers I can look for?
  Gti6/VTS Front Shocks/Springs MY95 14 7,136 05-10-2016, 08:23 AM
Last Post: Toms306
  Bilstein B4 front shocks pugman2014 9 5,390 22-06-2016, 04:14 PM
  Xsara vts front shocks / springs?? Tc306 5 4,288 06-06-2016, 09:23 PM
Last Post: Tc306
