no power to lift pump.
hi. Hoping someone can help.
I have no power going to my lift pump, car wont start but
If you hook up a live feed to lift pump the car start and drives
And soon as you disconnect the power it cuts out.
I have been told it could be the relay or the wiring. Does anyone
No which relay it is and where abouts it is? as peugeot wont let
Me order a new one with out the relay number.
Also if possible does anyone no where abouts the wires run through the car?
Thanks you for any help
Kris
The relay is the brown one behind the ecu, the wiring runs under the car iirc, but you can find out quite easily by following the wires coming off the pump. There's more information in the second link in my sig.
Thank you very much. Ill read through the link in sig.
Hopefully sort this out.
Best of luck with it, let us know how you get on. If you find the relay number would you be kind enough to post it in the guide or in here please, always on the lookout for new information. Smile
Dug my spare one out of the garage, part number on it is 240109.
Ooh, make sure you check your inertia switch as that kills LP power
Hahaha good shout, i always forget the simple things. Rolleyes
Hi sorry taken so long turnt out to be the relay, was nice and easy job to do and only cost £18, so im
Happy now. Saved stripping the car checking wires. Thanks for the help the guide was very helpful.
Glad we could help. Smile
  Won't start, think lift pump. daveylennon93 11 7,364 23-01-2017, 09:36 AM
Last Post: daveylennon93
  no power to lift pump thanhhungone 4 4,370 20-01-2016, 06:25 AM
  Fuel/lift pump Deangatt 2 2,766 21-08-2015, 12:38 PM
