No electrics
My car is completely dead, tried to charge it but no luck, I haven't bought a new battery, but the one i'm using isn't old, it's a new one which I bought just over 3 months ago. I'm sure it's an alternator issue. Any ideas on what is could be?
[Image: Untitled_zps2ed48460.png]
Does is jump start? Are the terminals tight on the battery?
I have no jump leads, so I have no idea. The terminals are tight, yes. I also gave them a clean but still no joy. I've had trouble in the past with batteries going flat.
Ideally mate you need to get hold of a multimeter and test the voltage output on the battery.
Can you get hold of a battery charger? Stick it on and see what happens!
To find out if the alternator is playing up, test the voltage when the car is running, you should get a much higher reading than 12v (somewhere around the 14 - 15v region). This shows that the alternator is working well.
How long are we talking before the battery goes flat? Is there something constantly on in the car which is drawing power overnight? Trace it if you can and then get back to us.
Regards
Rich
Black mask Service
Try and jump start it and see what happens.
I'm confused.... You tried to charge it but no luck? So the battery won't hold charge? Or is it charged but just not powering the electrics? Confused
(23-10-2013, 11:20 PM)Toms306 Wrote: I'm confused.... You tried to charge it but no luck? So the battery won't hold charge? Or is it charged but just not powering the electrics? Confused
Tom its broke duh. Learn to internet Wink
What's broke? It just sounds like he's left an interior light or something on and drained the battery to me. Tongue
(23-10-2013, 11:33 PM)Toms306 Wrote: What's broke? It just sounds like he's left an interior light or something on and drained the battery to me. Tongue
Nah they go off with ignition mate Wink
Boot light on the other hand
  Damaged electrics, possibly relay?? windrushelectrical 0 2,468 08-07-2019, 10:05 PM
Last Post: windrushelectrical
  last "whats this for" on electrics pug306driver 3 3,424 18-02-2016, 09:30 PM
Last Post: pug306driver
  Test Rig for Tow Bar Electrics insomaniac45 24 16,199 07-12-2015, 07:23 AM
Last Post: THE_Liam
