Reverse light intermittent
Noticed while reversing earlier that my light is intermittent.
If I put it in reverse and push the gear lever forward a tad, as though to take it out of reverse, the light illuminates.
If im just slapping it in normally (all the way in, giggidy) then the light doesnt work?
Lose wire, worn switch, or dud sensor? Any ideas pleasseeee
any help guys, really starting to bug me now. Completely off, seems the only way to get it to come on is to drive a bit quick down my driveway and it comes on?
Check the plug is fully in...
Might be a failing switch though, although I cant remember ever hearing of one failing on a 306 so its not common.
sweet, so where will i find said plug lol? Cheers
Are you definitely in reverse? :p
But on a serious note, as Tom said, check the plug, its on top of the gearbox Smile
You'll need to remove the airbox to see it iirc, has a grey plug, just under the clutch arm.
no worries, cheers guys will get a nosey at it asap! Smile
  Speedo and reverse lights! Help! Mac22 8 2,602 15-02-2017, 06:01 PM
Last Post: Mac22
  reverse lights pug306driver 0 771 02-06-2014, 12:47 PM
Last Post: pug306driver
  selecting reverse lights up drivers indicators :/ zx_volcane 9 2,250 01-01-2014, 12:33 PM
Last Post: Toms306
