Threads: 252
7
Car Model/Spec: Xud sedan/Xud estate
Noticed the HT leads are arcing (by noticed I mean felt as I was touching it) also when doing so its backfiring some pretty sizable flames up the carb. I am guessing its firing the wrong plugs. is this down to worn leads or Is it a different cause? I'm thinking just needing new leads
TD04 11mm Sedan, now 2.1 vnt
Sedan Project
http://306oc.co.uk/forum/thread-5763.html
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 170
5
Car Model/Spec: xud 1.9 dturbo
Video or it didn't happen
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 55
17
Car Model/Spec: 406 V6
23-10-2013, 11:22 AM
(This post was last modified: 23-10-2013, 11:23 AM by Rippthrough.)
Misfire + slightly worn valve seats/guides perhaps.
Mine does the odd blue flame up the inlet when it fires up in winter because the guides are getting tired and the extra ignition advance to get it started fires it off before the valve fully seats. Really makes the people at the petrol station happy.
Wind some electrical tape down the leads and see if it clears up.
Threads: 46
6
Car Model/Spec: Renault Scenic 2.0
i had this when i changed the HG on my last AX, turned out i'd put the ht leads on in the wrong order by mistake (not checking + 2am...lol) didn't have arcing though, i'd investigate what's causing that first...
Project: Formula Peugeot
Threads: 31
4
Car Model/Spec: tu5 bitza/cherry dt
Arkings normally a pin prick in the boot that surround the plug, makes for fun finding it, as ripp says electrical tape them and see if it stops
Threads: 252
7
Put duct tape on them and there fine now
Sedan Project
Blaze 1.6 Dead
Threads: 591
54
put new leads on you cheap ass.
or get a fire extinguisher fitted for when that duct tape catches fire
