Urgent- bream brake line
Hi I need the section of brake line which runs off the chassis to beam flexi pipe to the drum on the drivers side on a non ABS drum beam if anyone has a spare lying round?
Thanks
Stage 2 XUD Sedan
You'll most likely need one knocking up.
Try a motor factors; take the old ones in with the unions also and ask then to make it up to size
As Ginge says: get a new one made up, it'll be more worth your while.
Black mask Service
or a decent small garage. most will do it for a tenner.
originals now will be so fragile and a nightmare to post
Or get some brake pipe, unions and flaring kit, useful to have for the future
Defo worth the £15 a flaring kit costs... Renew all the pipes on a car for less than £30
Just remember peugeot are gehy and use a double flange, so you will need to consider that in relation to what kit you buy
(25-10-2013, 09:03 AM)Grant Wrote: Just remember peugeot are gehy and use a double flange, so you will need to consider that in relation to what kit you buy
Never noticed that, and I've replaced brake pipes on the 309, and Ax with my cheap kit from machine Mart with no worries
  Brake hard line Matt 3 2,584 17-06-2016, 07:56 PM
Last Post: swampy
  Rear brake line from caliper rd070707 1 2,044 18-04-2015, 09:37 AM
Last Post: zx_volcane
  Wanted: URGENT! Rear pads and brake line Nathan1305 8 4,752 01-09-2014, 06:17 PM
Last Post: Nathan1305
