Torsion bars will be the death of me.
Can't get any end of one of the torsion bars out. There seized. What to do? :/
[Image: DSC_0054.jpg]
What have you used do far to get them out heat, wd4, hammer etc etc
Not using a big enough hammer
Team Doesn't own a 306
A f*ck of sledge, alotta patience and a shit load of wd40
Also a pair of broad shoulders helps! But yeah, sledge hammer FTW! lol
A f*cking big sludge hammer & a well supported car.
If that dont work........... Then dont bother lol
Tried a sledge and wd40, moving the car on the axle stands haha
Went baiting at it again. No good. The arm has moved a few.mill and just won't move no more...
It will just got to keep at it, if it's started moving it will keep moving more whacks needed
I found a lump hammer works better get a better swing behind it
I remember when we did it to my 106, took a good hour hammering!
Only a hour your lucky lol
When i did it on the axle im rebuilding only took 30mins with the clarke strong arm, ask around see if any of your mates have got one defo helps out putting lots of pressure on why your whacking.
[Image: DSC_0158_zpsb278e269.jpg]
If you carnt get one of them just alot of wacking is the only option with heat and i find plus gas is better than wd40 Smile
like the look of that strong arm!
Last one I did made three attempts while on the car before dropping the beam and smacking on the floor with a sledgehammer that broke, and then going again with a bigger sledge.
Still only managed to remove one end of the torsion bars.
Which side you hitting? Generally drivers side is easier. You have removed the torx screws and arb? Try dabbing break fluid to the joints it penetrates well
www.prestige-auto-care.co.uk
Make a puller to put some pressure on the other end of the torsion bar and then smack it from the other side.
  Torsion Bars/ARBs - Sizes and Sources anto 43 71,350 26-02-2019, 10:53 AM
Last Post: Mighty306
  Stubborn torsion bars Mighty306 12 7,649 09-06-2017, 08:07 PM
  1.4 gear box death Frankwood 1 2,131 31-05-2016, 11:59 PM
Last Post: Rippthrough
