Threads: 65
1
Car Model/Spec: china blue gti6
Given 0 thank(s) in 0 post(s)
Aright, well I'm not really sure. I just want a bit more power without putting the engine at huge risk. I'm not sure how far you can push the engine before you need to start spending out on an uprated clutches and intercoolers and all the other bits n bobs
Threads: 39
4
Car Model/Spec: P2 Dturbo
just set it to 18-20psi and you'll be fine
Threads: 77
2
Car Model/Spec: 306 phase 1 bianca dturbo
17-10-2013, 08:10 PM
(This post was last modified: 17-10-2013, 08:23 PM by 306pc.)
I had a great little tune on my Lucas before swapping to a Bosch. Boost compensator right down turbo 100% up and keep turning max fuel till it smokes then down a touch. About 180 degrees on mine. Went well, 20psi. T2's can handle more boost than the kkk or GT15.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
I run my de-wastegated TD04L on my 205 with a Lucas pump. It's been so long I can't actually remember what it was boosting (on standard fueling)!
Threads: 65
1
Yeah, well like someone posted earlier on, every car runs a bit different, so it's just trial and error until you get the right settings
