Threads: 28
Car Model/Spec: D turbo 97 Stripped Interier
when tilting the engine forward i am aware i need to put a jack under the engine and undo the top mount.
is there anything else i need to be aware of? i.e removing certain pipes ect i dont want to crush something.
thanks
Threads: 129
11
Jack engine to remove pressure, remove top mount bracket. Done.
Some say its good to put some padding on the jack face to protect the sump but I've never bothered
Stage 2 XUD Sedan
Threads: 183
20
Car Model/Spec: moonstone hdi #2
Just small bit of wood will do.
Threads: 178
28
Car Model/Spec: HDi!
That's what I used on the hdi.
Threads: 170
5
Car Model/Spec: xud 1.9 dturbo
I use rubber piping like a boost hose
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 252
7
Car Model/Spec: Xud sedan/Xud estate
Steel sump I never bother. Might need to undo exhaust depending how far forward your going
TD04 11mm Sedan, now 2.1 vnt
Sedan Project
http://306oc.co.uk/forum/thread-5763.html
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 171
46
Car Model/Spec: Black 3dr Dturbo
Watch out for the coolanthose off the front of the block. I rocked it too far and it split the hose on the rad
Threads: 115
Yeah mate just use a block of wood wedged between the head and the bulkhead to hold it in place. There is a cut out in the chassis which is where I usually wedge it. As for the sump just jack it right on the corner if you don't have a block of wood as that is it's strongest point.
