Fitting a USB charging port
Anyone of electrical and ice capapbilities, just wanted to find out is it possible to hardwire usb port for either charginng mobiles and devices or as a AUX connection for music. I am looking at the possibility if the hardward exists while i am ripping out my dash on my Fiesta. I currently have a aux port in the fiest but thats a 3.5mm jack type.
cheers in advance
Get a HU with a rear USB and an extension ?
You want a 12v to 5v transformer then just a panel mount usb port and solder the 5v output to the power pin on the usb port. Job done.
(16-10-2013, 04:35 PM)Niall Wrote: You want a 12v to 5v transformer then just a panel mount usb port and solder the 5v output to the power pin on the usb port. Job done.
cheers are these sorts of things available in maplins or ebay??
also how about splicing a USB into an aux???
surely a ciggy usb would be easier
I would suggest going to pound land and buying a usb cig lighter attachment for yes you gussed it a pound and just dismantle the head off it and solder a 12v live to the inner terninals. Just my 2p worth.
http://www.ebay.co.uk/itm/TWIN-2-PORT-US...2ec97e92fb
that would settle the charging issue,
or alternatively Smile airplay
http://www.youtube.com/watch?v=qyey7tzbEFY
Project: Formula Peugeot
(16-10-2013, 04:59 PM)Fezza_rs Wrote: I would suggest going to pound land and buying a usb cig lighter attachment for yes you gussed it a pound and just dismantle the head off it and solder a 12v live to the inner terninals. Just my 2p worth.
yep do that.
the mighty car mods video above is superb as well!
Mightymods epic <3
Thats fairplay john1.4
transformers do not work on dc only ac
(16-10-2013, 07:12 PM)treborobert Wrote: transformers do not work on dc only ac
Im not clued up with things sparktrician, what does that mean?
Only household power can be transformed??
nah, AC can be at any voltage/current, it's just that the changing direction of the current induces a voltage on the second side of the transformer, in DC there is no direction change so doesn't induce a voltage across the transformer.
(16-10-2013, 08:14 PM)John1.4 Wrote: nah, AC can be at any voltage/current, it's just that the changing direction of the current induces a voltage on the second side of the transformer, in DC there is no direction change so doesn't induce a voltage across the transformer.
This!! But put simply, AC - Alternating current DC - Direct Current
You can get them on eBay, 12v reduced to 5v, I've got 6 of them on the way to fit, kids use iPods and stuff when in the back so fitting some inside the rear ashtray, my tomtom is USB powered, so I'll be fitting one on tip of the dash for that, my partners dad is a auto electrician so he will be doing all the wiring for me.
(21-10-2013, 01:06 PM)ArbGarry Wrote: You can get them on eBay, 12v reduced to 5v, I've got 6 of them on the way to fit, kids use iPods and stuff when in the back so fitting some inside the rear ashtray, my tomtom is USB powered, so I'll be fitting one on tip of the dash for that, my partners dad is a auto electrician so he will be doing all the wiring for me.
can you share the ebay link for the usb ports you are gonna buy. cheers
ebay usb
use a usb cig lighter take it apart and splice the wires in the back of cig lighter?
the link to the ones i posted work well, simple to wire in,
fitted in my car
[Image: IMAG0484.jpg]
  Alternator not charging Dreijers 1 2,545 17-06-2017, 10:39 PM
  Usb port deggerz 22 12,042 16-07-2014, 08:19 AM
Last Post: toseland
  ScanGauge / OBD2 Port Readers silverzx 12 7,556 26-04-2014, 04:39 PM
Last Post: C.A.R.
