Threads: 343
15
Car Model/Spec: 106 gti / 306 hdi estate
Given 3 thank(s) in 3 post(s)
So after the dyno other day wanna get a rev gauge on my 106. Hopefully you guys can help me out abit.
Were Will it pick up the reading for the gauge? Will my car have the wireing there?
Its worth mentioning that my car uses a Speedo cable it's not electrical!
Any help or tips welcome
Threads: 226
24
Car Model/Spec: A3 TDi
Given 0 thank(s) in 0 post(s)
Threads: 151
14
Car Model/Spec: 306 D-turbo
Chris Dosent have a coil pack as it's a diesel
Pretty sure you can wire them to alternator pal
Team Doesn't own a 306
Threads: 476
81
Car Model/Spec: 306 Rallye
good old mighty car mods <3
Threads: 169
91
Car Model/Spec: 2003 Jaguar S-Type Sport 3.0V6
Given 1 thank(s) in 1 post(s)
(14-10-2013, 08:08 PM)SRowell Wrote: good old mighty car mods <3
Exactly this!
Threads: 591
54
14-10-2013, 08:31 PM
(This post was last modified: 14-10-2013, 08:32 PM by Piggy.)
er, fit a 106 dial set that has a rev counter??
and before you shout your retort.. yes they do exist
and yes you can wire into alternator but you will need a lazer techy thing to calibrate it
Threads: 343
15
I've been trying to research this, some are saying off alternator, some say of the flywheel/crank sensor it's doing my head in
Would have though some one would have had fitted a rev gauge and wrote about it on the net.
@piggy I will struggle to find clocks with a Speedo cable And rev gauge, but will look tho.
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
Yes they exist piggy but simply plugging one in doesn't make it work as that's what someone's done in mine lol
Threads: 151
14
Said you should have grabbed them dials out of my diesel one I was breakin
Threads: 343
15
(14-10-2013, 10:10 PM)Danny2009 Wrote: Said you should have grabbed them dials out of my diesel one I was breakin
I no lol that's the only one I've seen to
Threads: 151
14
They are hard to get hold of shame I didn't take them out :/
Threads: 343
15
(15-10-2013, 09:45 AM)Danny2009 Wrote: They are hard to get hold of shame I didn't take them out :/
Looking at aftermarket rev gauges just need to find out of I can wire it up before I buy one
Threads: 151
14
Pretty sure i have seen you can wire up on alternator you been on 106 forum?
Threads: 343
15
(15-10-2013, 10:58 AM)Danny2009 Wrote: Pretty sure i have seen you can wire up on alternator you been on 106 forum?
Yer but my membership has run out so i carnt view diy guides, not paying just for this lol,
on this thread
http://106owners.co.uk/forums/showthread...ev+counter
He says the orange plug, witch is the crank sensor (but its grey plug on mine  ) Think im just gonna buy a gauge and wire it up then try it on that crank sensor see if it works or not
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
Welcome to my world! Been trying figure it out for my 205 1.9 for bloody ages!
Threads: 130
82
Car Model/Spec: 106 GO-NAD
just get one that will work off the 'w' terminal of your alternator. best to check if it has an exposed 'w' terminal tho lol
Threads: 591
54
the ones off alternator will work fine...but as said...they need calibrating
Threads: 266
18
I want an OEM counter, the STDT cluster also has water temp!
Threads: 343
15
(15-10-2013, 11:28 AM)silverzx Wrote: Welcome to my world! Been trying figure it out for my 205 1.9 for bloody ages!
Surely you just can buy an aftermarket one and just wire it to what ever sensor the 306 uses to pick up the rpms from?
(15-10-2013, 11:30 AM)samass Wrote: just get one that will work off the 'w' terminal of your alternator. best to check if it has an exposed 'w' terminal tho lol
Will have to look at that then. thanks
(15-10-2013, 11:31 AM)Piggy Wrote: the ones off alternator will work fine...but as said...they need calibrating
Just bought an aftermarket one now so will see if i can get that to work. Hope i can
Threads: 266
18
15-10-2013, 12:49 PM
(This post was last modified: 15-10-2013, 12:49 PM by silverzx.)
Yeah you can wire it up to the alternator but why have a "poo" aftermarket rev counter when you can stay OEM!
Threads: 18
3
Id stay oem
But it seems a farce so I wouldnt bother
Threads: 343
15
I've ordered an aftermarket one now so see how I get on with it, it's not a massive one tho just 52mm gauge
Threads: 18
3
Ah yea actually....I imagined one of them huge halford jobbies
Threads: 343
15
(15-10-2013, 03:33 PM)Arron Wrote: Ah yea actually....I imagined one of them huge halford jobbies
 yer I thought people might think I had a 6inch one with a shift light lol
Just a suitable 2inch one even tho it goes to 8,000rpm think a gov mod may be in order
