smoking on idle bosch pump
hi.
since fitting my bosch its very smokey on first start up idle.
when i first put the pump on it was too retarded and it smoked like hell and hunted, litterly filled the street with smoke.
its at 2/3rds advance at the moment and dosnt smoke nowhere near as much but is still too smokey should i advance it some more?
just making sure before i advance it some more, as i dont wana kill my engine i heard too much advance can kill the engine lol.
sounds like you've timed it up a tooth out . .
the timing belt is correctly timed, double checked that twice lol. its fine when its warm runs sweet. just on first startup or if its been sat for a few hours its really smokey and stinks!
What colour is the smoke. Mine is smoking and it stinks
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
blueish/black i think., definatly not white though lol
Mines blue if I leave it is garage on idle and go in my eyes start to hurt lol. Maybe injectors of advance the pump. That's what I think it wrong with mine. If revved it clears and blows black
Ph3 perv cab heaven
Black ph1 XUD died
If the smokes blue'ish.. it's burning oil
One of my old pugs use to cough on idle and blue smoke. Turned out to be a injector
Ph3 perv cab heaven
Black ph1 XUD died
All my xuds have smoked stupid colours in the morning, even with new stem seals!
Unless you are running veg it might be worth having a look at the injectors.
i dont run veg, it hasnt smoked on idle all afternoon, does still smell abit oily though when you stand near the car.
if its blue smoke again in the morning is that my stem seals then?
Mines being a tw*t too ever since putting a Bosch on. I'm sure it needs advancing. Also my accelotator pedal vibrates which is really annoying. Revved it manually from the engine hard and the pump vibrates?hoping new lines injectors and pump advance sort it out or in going back Lucas. It's embarrassingly smokey in the mornings. Although it was blowing smoke rings at work the other day wich was hilarious. I've got a hybrid turbo ready to go on as soon as I get the pump happy.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
This is what I got after changing the Lucas to a Bosch
Car ran fine on the lucas
Checked timing, but came down to a dodgy injector and the car needing a run.
problem solved, injector fuel return end cap was leaking! it was one of them cheap little red plastic blanks, put a propper sealed rubber one on much better
Gonna have a look at my injector leak off pipes, as mine has started doing this again! Think air gets in easier if you have low fuel in the tank because the air can rush into the tank when the fuel sloshes about in there, instead of having a full tank where the fuel is "plugging" the hole all the time. But I want to wait until my turbo change lol as I can't be arsed taking the intercooler off twice in a short space of time.
  Slack in bosch pump? dt_ 14 12,393 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 4,633 05-01-2020, 09:09 PM
Last Post: jamie182
  Bosch pump fuel screw broken Forby 0 3,208 12-03-2019, 06:47 PM
Last Post: Forby
