206 1.1 that won't pass its emissions test?!
Not a 306, I know, but it's my little brother's 206, 1.1. Initially when it failed its MOT the list was both rear tyres, beam, headlight adjustment, exhaust leak and lambda reading was too high. Simple list, right? Wrong.
Changed the beam, put two new tyres on, adjusted the headlight, fixed the exhaust leak (gasket had gone) and thought I'd fixed the lambda reading.
So far we've changed, the lambda (for an NGK one), fitted a type approved cat, serviced it (oil and filter and plugs), changed the throttle body housing. I've tried searching for air leaks by spraying brake cleaner over the air pipes and no change to the engine speed.
First MOT results:
% Vol CO : 1.413 (Should be below 0.3 %) FAIL
ppm HC : 168 (Should be under 200pm) PASS
Lambda : 0.977 (Should be between 0.970-1.030) PASS
Other readings:
Air-fuel ratio : 14.350
% Vol CO2 : 13.86
% Vol O2 : 0.47
Last MOT taken:
% Vol CO : -0.005 - PASS
ppm HC : 13 - PASS
Lambda : 1.062 - FAIL
Other readings:
Air-fuel ratio : 15.606
% Vol CO2 : 14.68
% Vol O2 : 0.87
So, as you can see the CO volume has dropped dramatically after changing all of the above, but now the lambda reading is too high, how does that work?!
More importantly, anybody got any ideas what I could try next? I'm tempted to buy a cheap ODBII reader and see what the sensors are telling me.
[Image: 306Green5DrSig.png]
had this on my first car - was a tiny leak in the exhaust, took ages to find... sealed it up and it flew through
Project: Formula Peugeot
Can't say I'd be overly surprised if this was that case, think I'll chuck it up on my ramps and check the exhaust properly, end to end. Cheers for the suggestion.
Also check the sensor earths in the engine bay are all clean - could be a slight voltage offset on the lamdba sensor.
We had this also. Got it passed eventually but never fixed the problem. Not going to bother this year just get another car
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
  MOT emissions fail data interpretation balkan_bozo 4 5,706 28-10-2018, 09:19 AM
Last Post: RetroPug
  Emissions :( Kristina 13 14,265 04-06-2018, 05:56 AM
Last Post: bashbarnard
  CO2 emissions baz1701 3 4,099 30-07-2014, 05:34 PM
Last Post: John1.4
