08-10-2013, 07:04 AM
Morning guys, just wondering if anyone can help me out. Trying to find the valve for the rear whiper jet on an estate. Every time I pull away it looks like the hulk has shot his load on the rear window!
Rear Jets
08-10-2013, 07:24 AM
its with the bottle if I remember correctly.
08-10-2013, 08:36 AM
Yup, sa above, the motor in the washer bottle feeds both front and rear.
Where it is coming out though? The estate washer jet is built into the wiper arm so doesn't usually work lol, you seem to be getting the opposite though!
08-10-2013, 08:42 AM
there are one way valves in the lines though...near the front end im sure...either next to the bottle or in wing near front wiper motor
08-10-2013, 08:55 AM
Ah ok, I assumed the pump contained the valves. But now I think about it, they always dribble when the pipes are pulled off so you're probably right!
08-10-2013, 04:12 PM
YEah no it works well but splatters up the rear window when I pull away, can anyone rustle up a picture with an arrow to the rough area where id find the valves?
08-10-2013, 04:21 PM
If it's in the wiper arm like a ph2 then cut a length of sky/virgin tv cable, take the outer casing off leaving just the copper core wire..poke this down the arm and it has lateral strength to break blockages. My ph 2 rear washer still works, probably the only ph2 rear that does
08-10-2013, 04:32 PM
Ha ha I shouldn't skim read
the smokey old bus that sounds like a tractor... |
Don't buy super cheap mist jets | wainwrightj | 6 | 2,640 |
04-05-2018, 02:50 PM Last Post: wainwrightj |
replacing windscreen mist jets | Doseph | 13 | 2,439 |
16-02-2016, 08:56 PM Last Post: Doseph |
Mist jets don't work on hdi? | doogle-d turbo | 10 | 1,617 |
02-10-2014, 08:33 AM Last Post: Toms306 |
