30-09-2013, 09:08 PM
![[Image: siggy1.jpg]](http://i653.photobucket.com/albums/uu252/crissy_boy/Cars/siggy1.jpg)
Old skool cool on a new plate...
30-09-2013, 09:10 PM
hows that possible?
I thought putting a new style reg on a car older than the year was illegal?! Wishes for more power...
30-09-2013, 09:13 PM
It will have just been registered late
30-09-2013, 09:15 PM
irish import maybe? seen it before with a R100 that should have been an R plater when it was imported back to the uk. I think there was either a f*ck up or they couldn't really prove what year the car was on, so it got the reg plate that was out at the time, which was a 56 plate.
according to the thing it was registered in 2003. can only assume it was a late one very late by the looks of it
97' 106 XT 1.6 - Mayerling Green - Swapped 95' 306 P1 DT - Onyx - Scrapped 97' 306 P2 DT - Silver - Scrapped 97' 306 P2 DT - Onyx - SORN awaiting scrap
30-09-2013, 09:25 PM
(30-09-2013, 09:15 PM)adamm306 Wrote: according to the thing it was registered in 2003. can only assume it was a late one very late by the looks of it That's what I thought, tempted to buy it as cheap tax lol ![]() the smokey old bus that sounds like a tractor...
30-09-2013, 10:04 PM
Manufacturer: Peugeot
Model: Not available Year: 1995 Colour: Silver Fuel Type: Heavy Oil Engine Size (CC): 1905 VIN: Not available V5C Issued: Not available Tax Status: Licence Due to Expire Expiry Date: 01/10/2013 Registration Date: 26/02/2003 6 Month Cost: £123.75 12 Month Cost: £225.00 The Tax is still pretty high or is that normal for a 1.9DT?
30-09-2013, 10:08 PM
my mates actually done a deal on this, picking it up on Saturday, apparently it used to be on an irish plate, its bosch too
30-09-2013, 10:17 PM
(30-09-2013, 10:08 PM)padge Wrote: my mates actually done a deal on this, picking it up on Saturday, apparently it used to be on an irish plate, its bosch too Arse ! But then again no cheap tax so... ![]() the smokey old bus that sounds like a tractor...
30-09-2013, 10:28 PM
Imports get put on imported years plate. Not relevant rear of manufacture. Just a case of common sense isn't present! I'm having a right ball ache because of this reason and that's just on an Northern Ireland import.
DVLA want the recent log book dated 2007 Dispite DVA (NI) log book dating 2013 Both v5c are the same except the DVLA has 1 previous keeper but the DVA has no previous keeper. Neither agency have acces to each other's systems simple cross matching and common sense would make it simple.
Perv 306 1.6 5 Door Hore - Sold 110bhp 207 Hdi Sport - Used as a Brake 173bhp T25 Ph1 Diablo Dturbo - Scrapped Thirsty Bitch Volvo 850 Estate - Sold 51bhp Berlingo Nad DT Van - Sold Slow as f*ck Dispatch Work Horse www.prestige-auto-care.co.uk
30-09-2013, 10:40 PM
its got a leaky water pump, heaters don't work.. hes sorting those out and putting 12 months test on too.
01-10-2013, 07:32 PM
(30-09-2013, 10:28 PM)Jenkosowls Wrote: Imports get put on imported years plate. Not relevant rear of manufacture. Just a case of common sense isn't present! I'm having a right ball ache because of this reason and that's just on an Northern Ireland import. Hold on, you expect two (unconnected) government departments to talk to one another? Do you do regular standup?!
01-10-2013, 08:15 PM
(01-10-2013, 07:32 PM)burnmw Wrote:(30-09-2013, 10:28 PM)Jenkosowls Wrote: Imports get put on imported years plate. Not relevant rear of manufacture. Just a case of common sense isn't present! I'm having a right ball ache because of this reason and that's just on an Northern Ireland import.
01-10-2013, 10:36 PM
(01-10-2013, 07:32 PM)burnmw Wrote:(30-09-2013, 10:28 PM)Jenkosowls Wrote: Imports get put on imported years plate. Not relevant rear of manufacture. Just a case of common sense isn't present! I'm having a right ball ache because of this reason and that's just on an Northern Ireland import. When both agencies use the same paper work same documentation pays into the same pot share the same taxing system and so on then being able to access the same system shouldn't be a problem. It'd be no different than me or you accessing this site.
06-10-2013, 09:25 PM
there's various 306's scattered around on newer plates, seen a phase 1 cab on a 52 plate once and the Silverstone track cars (gti6) are on newer plates...
06-10-2013, 09:33 PM
(06-10-2013, 09:25 PM)MCH Wrote: there's various 306's scattered around on newer plates, seen a phase 1 cab on a 52 plate once and the Silverstone track cars (gti6) are on newer plates... I guess a vehicle that's never been on the road i.e. an airport vehicle, when it then goes on the road, it is registered to go on the road and it uses the current year? ![]() the smokey old bus that sounds like a tractor...
Mine was manufactered in 1996 but its an s reg! So been sat waiting about for a while, so probably true for that
06-10-2013, 09:39 PM
(06-10-2013, 09:33 PM)devils_fuel Wrote:(06-10-2013, 09:25 PM)MCH Wrote: there's various 306's scattered around on newer plates, seen a phase 1 cab on a 52 plate once and the Silverstone track cars (gti6) are on newer plates... Correct. The date marker on a plate is not a sign of the vehicle age. Its a sign of the date (well within 6 months) of registration.
06-10-2013, 09:51 PM
Seen this tonight at mfn. Thought I had seen it somewhere but not sure...
So padge was it iris or late registration?
06-10-2013, 09:56 PM
I did see a 2005 reg Mk1 golf a couple of years ago (and no it wasn't a "golf city" south African import) mind you it didn't look in the best of conditions so perhaps an irish import or something
06-10-2013, 10:52 PM
(06-10-2013, 09:35 PM)Sian Wrote: Mine was manufactered in 1996 but its an s reg! So been sat waiting about for a while, so probably true for that Snap, MYA was made in early 96, registered late 97...hence it's annoying buying parts for her
yes mate it used to be an irish plate, its pretty tidy too don't you think?
12-10-2013, 01:23 AM
it used to be on irish plate no rust on inner arches or to be fair any where the only problem ive found is that the rear bushes bang to which i have brought some and there getting put on tomorrow. it even has a little red book inside which says the price of the car from new which was £15,440 with tax and 6 disc cd changer that it still has and a mountain of receipts and history with it
| Cool Mods for Skint People | Eeyore | 70 | 52,629 |
16-03-2020, 07:55 AM Last Post: Mighty306 |
| Looks pretty cool | titch | 9 | 6,336 |
13-02-2015, 08:16 PM Last Post: adam b |
| Sun strip - cool or no cool? | Orta | 39 | 19,607 |
23-11-2014, 09:16 AM Last Post: impotentials |
