Anyone got the black cast bracket on the engine that the pas pump bolts to and houses the auxiliary tensioners / idlers
For a ph2 d turbo
Cheers
For a ph2 d turbo
Cheers
Wanted: Auxiliary tensioners engine bracket
For a ph2 d turbo Cheers
26-09-2013, 09:57 AM
yes.
got a pic though as there a couple variations! Wishes for more power...
26-09-2013, 11:06 AM
different alternator mounts...as I found out
you need just bracket or tensioner/pulley too? Wishes for more power...
26-09-2013, 11:10 AM
Need the tensioner and pulley but thought it would be easier tho change the lot for a known working part
this is what I got available...
![]() ![]() but there is a variation with a auto sprung tensioner and a cammed lower pulley tensioner which I am running. Wishes for more power...
30-09-2013, 10:11 PM
dont think its that one mate, the one i need has a big spring tensioning it and dosent have the lower idler
30-09-2013, 10:12 PM
thats an upper idler! lol!
mines got the bit spring bit, and a lower adjustable pulley Wishes for more power...
| Wanted: Ph1 Tailgate Parts, Ph3 abs bracket | Sambarker | 2 | 2,881 |
01-02-2016, 11:09 PM Last Post: Sambarker |
| HDI lower engine mount/drive shaft bracket | titch | 4 | 3,637 |
03-03-2015, 11:57 AM Last Post: titch |
| Wanted: HDi Aux bracket and PAS pump | WiNgNuTz | 6 | 3,648 |
04-08-2014, 12:06 AM Last Post: mspdan |
