Threads: 591
54
so weird one...
ph3 boot lock, so no key.
it jammed on locked at castle combe, so I got in via back seats and popped it open.
then it worked fine for a day. this went on for a week.
Got bored of it. So checked wiring loom between body/boot. Looks like new.
Checked lock. Seemed sticky, so stripped down, greased up and it was loads freer. Tried it dozen times and all well.
A car journey later and it did it again.
So swapped lock servo motor.
And its done it AGAIN! grrrr.
what am I missing here?!?!
Threads: 87
48
Car Model/Spec: Rouge vallelunga 5 door Dturbo
Given 74 thank(s) in 70 post(s)
long shot . . . the rubber adjustable things at the bottom corners of the boot, maybe screwed out too far and holding it tight? like i say long shot . .
Threads: 591
54
I'll have a look! I'll take a long shot!
Threads: 591
54
thats the servo motor.
replaced it already. Same fault occurs
Threads: 386
87
Did you check the loom all the way back to the plugs in the rear quarter? If its a new loom might not have been pushed in tight. There's also an earth point around there somewhere iirc.
Threads: 591
54
bugger
turns out that I have two buggered servo motors!!!
So, now WANTED: boot servo motor!!
Threads: 62
10
Car Model/Spec: Golf 7 GTD : LBSC Rallye
Given 11 thank(s) in 11 post(s)
WD40 the shit out of it tbh!
![[Image: wallye-gtd.JPG?raw=1]](https://www.dropbox.com/s/pcxk1pgpaucznvr/wallye-gtd.JPG?raw=1)
HDi Owner for 200k/9 years
Threads: 591
54
yeah they are.
sorted now tho ta!
