Threads: 70
10
Car Model/Spec: HDi Estate
Given 9 thank(s) in 9 post(s)
Not a 306, but a 206! My sisters 206CC, 2 litre petrol version.
Driving back from work today and her engine light comes on, with a message saying 'Catalytic Converter' (I wasn't there so not sure of exact wording)
I'm obviously going to hit google now and look but as it's a Peugeot perhaps a common problem with the petrols? Early results are to see if it just goes away, or perhaps plugs/coilpacks need changing.
Apparently the car was no slower for the warning light and didn't judder/stall at all. So don't think it's the cat itself but something up/downstream of it possibly?
Threads: 541
124
Is it Multiplex or an early car?
Could be a lambada sensor
Threads: 581
195
EOYLS (or what ever the hell it is) fluid. Its a anti pollution fluid that runs out over time and has to be topped up but you can turn the system off with pug planet (i did this with Dumdums 406 coupe).
Or, you can get the fluid from pug but i think its fairly expensive and highly toxic. not nice to change!
Threads: 386
87
EOLYS fluid is only used in DPFs afaik.... So won't be in his petrol 206.....
Threads: 581
195
(24-09-2013, 10:02 PM)Toms306 Wrote: EOLYS fluid is only used in DPFs afaik.... So won't be in his petrol 206.....
Ah your right. I had seen it as a fault on the 206 GTi before but ive only just found out they do a GTi HDi!
Threads: 141
35
Car Model/Spec: 106 rallye, GTi6, Hdi dturbo
My brief stint in a 206gti 180 had that come up all the time after going through a watersplash with a hot exhaust. I presume it buggered the cat up or something. Never bothered to investigate because it was rear ended a few days later lol
Threads: 91
83
Catalytic converter overheat warning probably...
Lambda is nothing to do with the cat or DPF...
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in.
Threads: 70
10
Thanks all for the input!
