Brake pipe nuts.....
Anyone know the size off hand, I seem to remember they are 10mm but a friend has said they are 3/8 unf....
If not ill whip one off.
Thanks
Jamie
They are 11mm...
(16-09-2013, 01:50 PM)Toms306 Wrote: They are 11mm...
Apologies, I mean the thread size ....
Jamie
Most are m10x1
You will find a couple of m12 though on things like the compensator
(16-09-2013, 02:01 PM)swampy Wrote: Most are m10x1
Just had a quick look and my M10 die won't go on and M12 seems way too big... My pipe that runs from rear compensator / flexi to the rear calliper has seized and snapped on removal, trying to order some ends and it seems everywhere says they are M10 but as I say the die won't go near it???????
M10 x 1mm, not M10 standard (which is 1.5mm).
Put an M10 die down it and you'll ruin the thread.
Yeah I know, but was just seeing if I could catch the thread to see if it was M10 fine of not..... I'll have to take a gamble and order them in M10, thanks for that
Jamie
Can 100% guarantee that the m10 unions are as said m10x1 its the industry standard these days for most cars
(16-09-2013, 03:18 PM)swampy Wrote: Can 100% guarantee that the m10 unions are as said m10x1 its the industry standard these days for most cars
Thanks very much, I've just ordered some!!!!
Jamie
  Brake pipe failure Mighty306 3 4,273 15-08-2020, 03:27 PM
Last Post: ekjdm14
  Do I buy? rear brake pipe corroded, covered in grease or other material pipes Charlie0 3 12,860 18-04-2019, 10:14 AM
Last Post: Mighty306
  Plastic brake pipe clips Mighty306 3 3,948 12-04-2018, 01:25 PM
