Threads: 7
hi ive got some new cyclones so the cylone 2 instead of the older 1? now i understand they have different bolts however the bolts ive got are for the older cyclone 1 just wondering if these will fit? i know the bolts designed for the newer cyclones wont fit the older cyclones due to the shoulder on them but what about the other way around?
thanks in advance
Threads: 7
so the older bolts wont fit a steelie? is that why they changed to the newer design then?
Threads: 465
114
Car Model/Spec: Vauxhall
Given 97 thank(s) in 92 post(s)
16-09-2013, 07:01 AM
(This post was last modified: 16-09-2013, 07:01 AM by cully.)
they changed to the newer design probably to save money in not supplying a fifth alloy as a spare
no the older bolts dont have the taper that is needed for the steel rim fitment so they wont work safely
Threads: 38
Car Model/Spec: d turbo s
Can u use the supermarket tapered bolts with cyclones then
Threads: 591
54
no, facepalm because this thread is just going round and round with the same questions and answers!!!!
