Wanted: Bosch Set up
Not sure how much they ususally go for.
Looking for an unmolested set up (if there is one out there any more) so i can play with it myself.
also what does the whole set up contain?
Whole setup contains:
- Bosch Pump
- Bosch Fuel Lines
- Bosch Injectors
- Woodruff key
To fit it you will need:
- Injector socket
- Length of Electrical Wire
- Length of fuel hose
but would also recommend:
- Cam belt kit
- Water pump
- Aux belt & tensioners
- Glow plugs
Edit: added woodruff key (Ginge).
ah ok thanks!
dont forget woodruff key, a lot of setups dont come with them - when you purchase, make sure it has the original/same woodruff key - as above, recommend all of that.
How much am i looking at for the kit?
From a scrap yard £40-£60.
From eBay £10-£150.
From a forum member £60-£150.
Thanks for you help chaps!
+ 1 rep to you both....oh wait
One friend of mine have one, all repaired and updated to use 2257 (?) turbo
[Image: sign.png]
↑ Project ↑
Ok need a whole kit let me know if you have it!
theres a xantia turbo d with a bosch in the scrapyeard near me, when i asked the guy about it he said itd prob cost 80 quid for the pump, not including lines and injectors and stuff.
Some scrappys will rip you off for these
306 HDI, soon to be XUD
which is why you fill your pockets... and 'forget' tools in the car...
i do this all the time lol
samass Wrote:theres a xantia turbo d with a bosch in the scrapyeard near me, when i asked the guy about it he said itd prob cost 80 quid for the pump, not including lines and injectors and stuff.
you got link to where the scrappy is?
http://maps.google.co.uk/maps?hl=en&cli ... d=0CDEQ_BI
there it is
  Wanted: Wanted - Bosch setup Dazecoop 1 2,219 06-04-2016, 01:32 PM
Last Post: silverzx
  bosch wanted Mac22 2 2,484 11-04-2015, 08:32 PM
Last Post: Mac22
  Wanted: Wanted full Bosch set up ASAP daniel909 3 2,898 15-07-2014, 04:17 PM
Last Post: daniel909
