Wanted: 3 door right window regulator
07-09-2013, 05:16 PM
Got to be someone on here breaking a 306 with 1 of these available?
PH1 FTMFW!
I have a whole unit sat here £40 posted!
Ιts the 2 pin plug ![]() ![]() Let me know bud Just so you know I don't do paytheif only bank transfer, but many people on here can vouch that Iam trustworthy,
14-09-2013, 03:38 PM
You can take the plug out of the motor and put your old one in. Its like an adaptor that just clips in.
Also, i can vouch that Jonny is trustworthy albeit an annoying old bastard!
14-09-2013, 08:36 PM
I will try and have a look this week to see if I have got 1
15-09-2013, 08:22 PM
I should be going to my 306 stores tomorrow after work so I will let you know
16-09-2013, 08:07 PM
I had a look mate but all the 1s I got are the square connector. I think the 1 you got is an aftermarket 1. I would say get a square connector 1 and get the plug with some wires on it and wire that in. You could take the 1 out of your d turbo
17-09-2013, 07:04 AM
I really don't want to be chopping up the loom tbh or I would of done that already
, could it be a ph 2 or 3 connector?
PH1 FTMFW!
17-09-2013, 07:24 AM
17-09-2013, 07:30 AM
Nope, was bolted on. Can't see any evidence of the door or loom being messed about with. Are there different plugs for 1 touch windows?
PH1 FTMFW!
17-09-2013, 12:22 PM
I would say that as the motor was bolted on it has had a motor before which would say it had an aftermarket 1 fitted.
I think the motors are the same for the normal and 1 touch windows. The 1 touch 1s have different wiring and a control box.
20-09-2013, 11:10 AM
I have a drivers door on the ph1 I'm breaking with working one touch electric window
| Wanted: phase 3 d/door window switch | pug306driver | 2 | 4,158 |
09-01-2021, 05:39 PM Last Post: pug306driver |
| Wanted: Passenger side window mech and door lock | Piggy | 0 | 2,217 |
07-05-2018, 05:22 PM Last Post: Piggy |
| Wanted: 5 door leccy window parts & switches | Magenta Sunset | 4 | 4,175 |
21-06-2017, 06:51 PM Last Post: Magenta Sunset |
![[Image: qolv.jpg]](http://imageshack.us/a/img197/2889/qolv.jpg)
![[Image: gakm.jpg]](http://imageshack.us/a/img839/1871/gakm.jpg)
![[Image: h9bv.jpg]](http://imageshack.us/a/img405/1631/h9bv.jpg)
![[Image: ygaja9yd.jpg]](http://img.tapatalk.com/d/13/09/14/ygaja9yd.jpg)
![[Image: jy8enese.jpg]](http://img.tapatalk.com/d/13/09/14/jy8enese.jpg)
