Potential Boost Leak
Hi all as some of you are aware I crashed my P1 and recently bought a P2
it has a cat and a lucas which could be the reason for it feeling ALOT slower than the P1 but my guess is a potential boost leak
when driving the turbo is very loud and i mean when im driving at 60+ it sounds like the heater fans are on full blast when I put my foot down and it seems to struggle to get up hills.
Other than the big pipe on the left hand side of the IC and the D-seal where else can I check for leaks if anywhere?
before anyone has a go at me i have searched for this only guide I could find was a paid subscribers one on 306.net
Any help would be appreciated thanks.
Sounds like a boost leak to me!
I'd be looking in the places you say as well as the manifold gaskets
You'll ideally need a boost guage to check what psi you are actually getting
If you ever need a hand with anything. Me and tom are quite handy with a spanner and I'm like 2 miles from you lol
ive had a boost gauage for like 2 months but never got round to fitting it lol
and yeah thats awesome are you on facebook atall? its easier to get in contact with people on there could do with a hand now and then
ill order a dseal anyway as if im inspecting it might aswell change it
thanks
I need help as well if possible Fitted a boost gauge and standard I was getting 10 psi spoke to derv doctor and from my turbo which he said is a gt15? I should be getting 14 easily I've turned up my fuel pump, turbo and boost compensator ad I'm only just getting 14-16 psi redone my d seal and I've checked all my pipes and carnt seem to find any leak ??
Can anyone help??
Plus I have the same wooshing sound when I boost but really carnt find anything??
(06-09-2013, 12:46 AM)Dan306DT Wrote: I need help as well if possible Fitted a boost gauge and standard I was getting 10 psi spoke to derv doctor and from my turbo which he said is a gt15? I should be getting 14 easily I've turned up my fuel pump, turbo and boost compensator ad I'm only just getting 14-16 psi redone my d seal and I've checked all my pipes and carnt seem to find any leak ??
Can anyone help??
Are you getting allot of on boost smoke? If not more fuel and boost!
www.prestige-auto-care.co.uk
bump.. where else can i check except these 2 places
the pipe coming off the bottom of the IC in the middle (where you connect a boost pipe to) seems to be bit oily after a drive hard could it be leaking out of here?
(06-09-2013, 07:25 PM)adamm306 Wrote: bump.. where else can i check except these 2 places
Yes could be that.
Split pipe from turbo to intercooler, could be either of those connections.
Could be a split intercooler (rare)
D seal could be f*cked.
Manifold gasket could be leaking.
awesome just the post i was looking for thanks Smile
will get investigating over the next week or so Tongue
wasnt hard to find the problem lol [Image: IMG_2406_zps09ea4fda.jpg]
Glad it was an easy one!
yeah hopefully that does the trick didnt have a d seal to hand to replace it with will do it over the weekend and see the results touch wood there is no other leaks
  boost leak ? Motatalk 3 3,064 19-06-2015, 07:46 AM
Last Post: Dave
  Boost leak... philpemberton94 6 5,070 13-06-2014, 10:31 AM
Last Post: toseland
  boost leak? willJspears 11 6,937 02-02-2014, 05:22 PM
Last Post: willJspears
