Wanted: piece of exhaust pipe?
Hi all im putting a straight threw to replace my rear back box, just wondering if anyone has a piece of exhaust pipe which I can modify to fit? Wolverhampton or close to it. Smile
Try your local exhaust centres, they might have some scrap pipe you could stick together if you're lucky. Smile
what size?
Standard size im guessing 2.25? or a little bigger so it can fit nicely over the centre section after removing the olive tip?
you iz a bit far. shames
You can buy bits the exact size off eBay either to clamp on or weld on, that's what I got to replace the cat with
Breaking another cab Dan, Come & grab the centre section.
Chris.
Will give u a text later today mate.
As said eBay will do a meter of 2.25 mild steel for £12 iirc which did the backbox with about 20cm of pipe left
  406 FMIC inlet pipe and turbo pipe Paul_13 3 3,630 18-12-2014, 06:00 PM
Last Post: Paul_13
  Wanted: 3 inch air feed flexible pipe/alloy pipe Chris_90 17 11,928 09-11-2014, 11:20 PM
Last Post: eskimogod
  Wanted: 2.5" exhaust pipe length Piggy 7 3,723 23-06-2014, 11:01 PM
Last Post: Seb_Ryan
