03-09-2013, 03:44 PM
Hi all im putting a straight threw to replace my rear back box, just wondering if anyone has a piece of exhaust pipe which I can modify to fit? Wolverhampton or close to it.
Wanted: piece of exhaust pipe?
03-09-2013, 03:52 PM
Try your local exhaust centres, they might have some scrap pipe you could stick together if you're lucky.
03-09-2013, 11:05 PM
Standard size im guessing 2.25? or a little bigger so it can fit nicely over the centre section after removing the olive tip?
04-09-2013, 12:52 AM
You can buy bits the exact size off eBay either to clamp on or weld on, that's what I got to replace the cat with
04-09-2013, 06:55 AM
Breaking another cab Dan, Come & grab the centre section.
Chris.
04-09-2013, 07:51 AM
Will give u a text later today mate.
04-09-2013, 11:48 AM
As said eBay will do a meter of 2.25 mild steel for £12 iirc which did the backbox with about 20cm of pipe left
![]() TEAM CONROD SHITTING RALLYE! |
| 406 FMIC inlet pipe and turbo pipe | Paul_13 | 3 | 3,786 |
18-12-2014, 06:00 PM Last Post: Paul_13 |
| Wanted: 3 inch air feed flexible pipe/alloy pipe | Chris_90 | 17 | 12,516 |
09-11-2014, 11:20 PM Last Post: eskimogod |
| Wanted: 2.5" exhaust pipe length | Piggy | 7 | 3,915 |
23-06-2014, 11:01 PM Last Post: Seb_Ryan |
