xud9 bosch pump timing in degrees tdc?
Does anyone know the timing and the timingcurve in degrees?
I know that there is a timing hole on the beltside but im experimenting a bit here.
is the engine at tdc when locked at the flywheel?
(03-09-2013, 03:16 PM)Dennis Wrote: Does anyone know the timing and the timingcurve in degrees?
one would assume so but in all honesty i don't know for sure, someone will be along that knows though . .Smile
Tdc at cylinder 1 when the flywheel is locked. Dont know about timing curves and things...
Ok, then i can at least see what it is!
  Slack in bosch pump? dt_ 14 11,964 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 4,502 05-01-2020, 09:09 PM
Last Post: jamie182
  Lucas pump timing probe issues weka 0 2,822 21-03-2019, 08:39 PM
Last Post: weka
