Few bits (new bits added 16/09)
Oil Cooler Lines 1/2" BSP, brand new - 33" long (long enough to go from your filter around your radiator) - £55 posted
[Image: IMAG0690.jpg]
Passenger Side Rallye Blank - £8 posted
[Image: IMAG1145.jpg]
Lynx scoop - £15 posted (has a little crack in it, nothing major)
[Image: IMAG1140.jpg]
Low boost/GTi6 K&N air filter - £20 posted
[Image: IMAG1142.jpg]
Rear wiper motor with relay - £15 posted
[Image: IMAG1141.jpg]
Peugeot rear mud flaps - £15 posted (one bracket is loose, but you screw straight through it anyway so it'll be fine on the car)
[Image: IMAG1151.jpg]
Pagid discs 302mm brand new (c4/307 I think) - £38 delivered
[Image: IMAG0560.jpg]
Rallye aux setup - £45 posted (no belt)
[Image: IMAG0577.jpg]
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
bumpo
Are the front speakers a straight fit ? If so do they work all good ?
[Image: IMG_4192edit.png]
(06-09-2013, 03:23 PM)ethanhp1991 Wrote: Are the front speakers a straight fit ? If so do they work all good ?
I have those speakers. They are a straight fit and are a very good upgrade over standard.
[Image: 20120704_212316.jpg]
Awesome stuff so for £15 that's a good deal ?
Are the speakers still availible?
(06-09-2013, 10:54 PM)306Dan Wrote: Are the speakers still availible?
If it is then I get first dibs lol
1/2" BSP...how does that relate to AN size/fittings?
Ill put seconds on the speakers then =D
Crikey.
Guys, i've had an enquiry about the speakers by PM. He was genuinely in first so i'm awaiting confirmation. Smile
For the oil cooler lines I am not sure what the compatibility of AN/BSP.
Speakers and door mirror sold. Smile
Bumpski
As the speakers aren't there anymore I'll assume they sold
As per previous post they sold to the first enquirer, thanks.
Ok bud thanks anyway
(01-09-2013, 12:58 PM)C2K Wrote: Miles gear linkages - £25 posted - some spring clips missing but Miles says they'll
FREE BUMP
small splitpins work too! through the holes to lock them, to stop the rods lifting
Gear linkages, spoiler, throttle body, fuel rail and injectors sold.
Bump for the weekend.
  306 Bits Toms306 6 7,606 02-03-2020, 07:49 AM
Last Post: Mighty306
  Bits for sale zekegti6 4 4,664 01-01-2020, 11:08 AM
Last Post: Claudauer
Smile 306 HDI Project bits 306clot 0 2,748 20-04-2019, 02:12 PM
Last Post: 306clot
