31-08-2013, 09:01 PM
I'm after the 2 bolts that hold the caliper/brake pad holder thingy to the hub need them for both sides (4 bolts) any one got some knocking around I can have cheap?
Wanted: 266mm caliper bolts
31-08-2013, 09:28 PM
they the same as any other caliper bolt?!
I do have a set of 306 caliper bolts though if needed? Wishes for more power...
01-09-2013, 08:00 AM
The 247mm bolts are a bit longer when I upgraded to 266mm I had to use a washer to make them fit
01-09-2013, 08:18 AM
(31-08-2013, 09:28 PM)Piggy Wrote: they the same as any other caliper bolt?! there different on the for the 106 i believe, are yours out of the 266mm brakes?
01-09-2013, 08:57 AM
(01-09-2013, 08:18 AM)Chris_90 Wrote:(31-08-2013, 09:28 PM)Piggy Wrote: they the same as any other caliper bolt?! You mean the carrier bolts? I have a set of 266mm here you can have bolts if you'd like
01-09-2013, 09:53 AM
(01-09-2013, 08:00 AM)aggyj17 Wrote: The 247mm bolts are a bit longer when I upgraded to 266mm I had to use a washer to make them fit This if you mean calliper carrier bolts, I did exactly the same ![]() the smokey old bus that sounds like a tractor...
01-09-2013, 09:58 AM
(01-09-2013, 08:18 AM)Chris_90 Wrote:(31-08-2013, 09:28 PM)Piggy Wrote: they the same as any other caliper bolt?! you sure?!?! I test fitted the 266s to my mrs and all the 106 bolts needed was a washer as already mentioned. yeah I have 4 carrier bolts from 266 306 brakes. Wishes for more power...
01-09-2013, 12:12 PM
think i will try the washers then get back to you i just under stood they was to long.
| Wanted: Caliper carrier bolts & abs sensor stuff | mcglynn | 7 | 3,800 |
31-10-2014, 09:06 PM Last Post: mcglynn |
| Lucas/Girling Caliper Carrier Pin or Caliper Carrier | MY95 | 0 | 1,758 |
16-02-2014, 06:11 PM Last Post: MY95 |
| Rear caliper bolts | zekegti6 | 2 | 2,001 |
09-02-2014, 06:44 PM Last Post: zekegti6 |
