Power Flex Rear Beam Tensioning Kit
What do these do, how do they fit and are they worth having?
http://www.powerflex.co.uk/road-series/p...t/681.html
they do what they say they do!!!!
but generally considered crap and not worth it.
I am, and I think another owner is, working with powerflex to make some proper rear uprated bushes.
(28-08-2013, 03:56 PM)Piggy Wrote: they do what they say they do!!!!
Just can't figure out how/where they fit to figure out how they actually add tension to the beam.
Don't think I'll bother lol
they fit in the gaps in the rear bushes on the rear beam.
peanut shaped gaps
(28-08-2013, 03:59 PM)Piggy Wrote: they fit in the gaps in the rear bushes on the rear beam.
peanut shaped gaps
Ahh............makes sense!
Cheers
Theres no reason why they wouldnt work, but i would of thought a set of proper solid beam mounts would be better.
For the price well worth getting to stiffen the beam a bit more or if old ones are getting knackered and no funds to buy solid ones.
I'm not really too fussed, just thought if they made a good difference they would be worth buying for the price :-)
when you see them, you realise what a bodge they are....
.however I will be fitting mine, I will try and sort some pics for you, while I wait for powerflex to work on full replacement bushes
thats shit concept of stiffening up your passive rear steer , lmao think it would benefit slightly more if you were fitting new mount
(28-08-2013, 04:40 PM)Bender Wrote: For the price well worth getting to stiffen the beam a bit more or if old ones are getting knackered and no funds to buy solid ones.
My mounts are fine, just couldn't work out the concept of these and if they were really worthwhile.
Look at my project and you'll see these fitted. They go in the little gaps on the square beam mounts, screw through the top to hold them in. Car felt a bit more stable while still having a bit of rear steer. They are a half way house between standard and solid mounts really
Edited to attach pics
[Image: 2yrahasu.jpg]
[Image: mynymuja.jpg]
[Image: 4ary5aha.jpg]
PH1 FTMFW!
Better off buying some new mounts, Or just stick some hard setting rtv in the hole
(28-08-2013, 07:15 PM)SKoob Wrote: Look at my project and you'll see these fitted. They go in the little gaps on the square beam mounts, screw through the top to hold them in. Car felt a bit more stable while still having a bit of rear steer. They are a half way house between standard and solid mounts really
Thanks for posting the pics up SKoob :-)
(28-08-2013, 09:15 PM)miles Wrote: Better off buying some new mounts, Or just stick some hard setting rtv in the hole
Yeah I would think that would do the same job.
not really.
the rear mounts when new still flex in your hand...they do that for a reason, the passive rear steer. the little inserts almost wipe out that movement. If they were the price of peanuts(!) it be ok...but they too expensive at rrp for my liking
  Rear beam ...the good and the bad Mighty306 35 31,649 23-07-2020, 10:13 PM
Last Post: Mighty306
  Rear Beam Pgtips 1 3,444 26-06-2020, 07:19 AM
  Rear beam rebuild MOK 21 16,076 18-03-2019, 03:40 PM
Last Post: MOK
