Pugmarshall's Miami 205 TD [pic heavy]
After spending 8 weeks searching for a diesel 205 this turned up, near Liverpool, on eBay.
I took a risk and put an offer of £525 on it and the seller accepted. I originally thought the car was a NAD but when buying insurance I found it was actually a Mardi Gras DT (XUD7T), which was a bonus! At least I wouldn't get bored so quick whilst I was collecting bits for it...
I bought it with 149k on the clock, a couple of months MOT, anthracite 1.9 GTi wheels and in pretty good condition.
The car as I bought it;
[Image: IMG-20130504-WA0001_zpse859af00.jpg]
[Image: IMG-20130504-WA0000_zps7886d98c.jpg]
[Image: 2013-05-30201520_zps5d2a92c6.jpg]
[Image: 2013-05-25121008_zps24d81d59.jpg]
First thing I did was give it a service and a good looking over. It had play in the lower steering Universal Joint, dodgy brakes and some fuelling issues (cutting out on roundabouts flol).
The only single problem in ~6k miles of complete thrashing, a snapped a PAS belt;
[Image: 2013-07-16233047_zpse4cd270c.jpg]
Fitted a boost gauge, wired from the cigarette lighter. Also used a pod made by Gareth7;
[Image: 2013-06-02225739_zpse88b8234.jpg]
[Image: 2013-07-13200904_zps9a058f8a.jpg]
Sprayed the rear bumper satin black;
[Image: 2013-06-21151117_zps44439596.jpg]
[Image: 2013-06-21153721_zps863c51a4.jpg]
[Image: 2013-06-21155131_zps5500cee3.jpg]
[Image: 2013-06-21160912_zps4bd61eb5.jpg]
[Image: 2013-07-13164104_zps5a763428.jpg]
Haven't done the front yet as I'm trying to find one in decent condition.
tidied up the slam Panel:
[Image: 20130818_191046_zps18b73a0c.jpg]
[Image: 20130819_171658_zpse24fb200.jpg]
Random pictures;
[Image: 2013-07-13164126_zpsceb6c42e.jpg]
[Image: 2013-06-28214053_zps7bc0b35d.jpg]
[Image: 20130730_202930_zps00dfca37.jpg]
[Image: 20130730_193801_zps06647f33.jpg]
[Image: 2013-07-18212907_zpsbbbd6049.jpg]
I basically started hoarding parts and just driving the car for the next few weeks. In this time I'd covered around 6k miles and decided to fit all the bits I had collected and drop the engine out for a 1.9.
The engine I used was bought from Piggy for the grand price of £75. The engine had a recent clutch, cambelt and head gasket and even came with an XUD9 gearbox, which I also used.
[Image: 20130912_002223_zps5f84cb88.jpg]
car on the ramp;
[Image: 20130913_195714_zpsc2cd3b2e.jpg]
[Image: 20130913_213941_zps0bd2898f.jpg]
After snapping many, many seized bolts and breaking a breaker bar, the engine was free.
[Image: 20130914_144957_zps096e008a.jpg]
Swapping the 306 diff for the 205 one
[Image: 20130914_220251_zpsc2901160.jpg]
Original 205 diff on the bottom;
[Image: IMG-20131009-WA0017_zps6ivwwndd.jpg]
New engine slotted in nicely;
[Image: 20130915_162855_zpsa2ca3ecd.jpg]
[Image: 20130915_165411_zpsf596a407.jpg]
[Image: 20130915_171351_zpsa6208590.jpg]
All running and working;
[Image: 20130917_021126_zps835390c7.jpg]
Whilst I had the car apart I fitted new strut top bushes and bearings and some -30mm lowering springs;
[Image: 20130915_235218_zpsf452ca2c.jpg]
[Image: 20130916_001023_zpsf18a5e71.jpg]
309 GTi wishbone on the left, 205 GTi on the right.
[Image: 20130914_162631_zps4b03bdb4.jpg]
I also fitted new track rod ends after 10 bottles of WD40 and a shit-ton of heat;
[Image: 20130918_200853_zpsbfe802ae.jpg]
The whole coolant setup was basically an XUD7 setup with an additional bleed screw and removed oil cooler.
After changing the XUD7 oil filter sandwich plate for an XUD9 one (running a Renault Clio oil filter due to space limitations!) due to a severe oil leak, sorting couple of coolant leaks and bleeding the coolant, I took the car for a short test drive...
I then double checked everything, adjusted the tracking and played with the fuel pump a little;
[Image: IMG-20131009-WA0010_zpss8e0rfdb.jpg]
Once I was happy I drove the car the 25 miles home at 3am.
I spent the first few days sorting coolant leaks and ironing out the niggles
Coolant leak due to warped thermostat housing;
[Image: 20130918_152741_zps2ccbf44d.jpg]
Various fuel leaks. New leak off pipes and fire seals solved that;
[Image: 20130918_152751_zps99f6d619.jpg]
I called upon Zakk (Ozonehostile) many times due to a poor AUX setup / poorly charging battery;
[Image: 20130918_174532_zpsabb058b4.jpg]
[Image: 20130918_174606_zpsfdc4db39.jpg]
(HUGE ARCH GAP FTL)
A picture of the EPIC cheese wedge stance!
[Image: 20130929_171214_zps2d8931dd.jpg]
'Finished' product as an XUD9TE powered 205;
[Image: 20130924_185958_RichtoneHDR_zps1fed417a.jpg]
[Image: 20130924_185833_zps7a606a34.jpg]
(^^Number plate has since been fixed)
[Image: 20130924_190840_RichtoneHDR_zpsf26b1792.jpg]
[Image: 20130924_190851_RichtoneHDR_zpsb79a2106.jpg]
Spec at this point;
Peugeot 205 Mardi Gras TD:
XUD9TE D8a engine
KKK K14 Turbo
XUD7 coolant system
306 Bosch fuel pump & injectors
Gov & LDA mods
Audi TT Fuel Filter
306 Dturbo gearbox
205 1.6 GTI diff & driveshafts
205 STDT / Dturbo hubs
205 1.9 GTI brakes (vented discs)
205 GTI -30mm lowering springs
309 GTI wishbones
NON-PAS steering rack and column
De-back box pipe
I had a massive amount of fun in this car for the next few weeks... Embarrassed a fair few modern cars and anti-derv idiots!
After going for more and more boost, the turbo finally gave in. I eventually maxed the 9mm pump out and couldn't get the K14 to give any more than 35-36 PSI, this ended in quite a beautiful climax;
[Image: 20131002_201844_zpsa7a18e92.jpg]
[Image: 20130930_163651_zpsf24b42f2.jpg]
after getting my dad to tow me home with his Partner van, I swapped the turbo in 3 hours, pissing rain after work (started at 6pm) and I was out terrorising the VAG fags that same night.
[Image: IMG-20131003-WA0006_zpsa7dbc72b.jpg]
I replaced the turbo for another K14 and, once again, maxed the pump, this time only giving me 32 PSI and 6 days of boost.
[Image: 20130920_191702_zpsa56c9afa.jpg]
After this and a few other problems I decided to take the car off the road and buy something more reliable, therefore the 205 is currently sitting whilst I collect more parts and build another engine for it.
Watch this space!
MASSIVE thanks to ozonehostile / Zakk for never letting me down when I was stranded, use of the unit / tools / estate ect ect - Top guy!
Thanks to;
Joe Rowlands for all of the bargains!
James / Piggy for the super cheap engine and bits!
Lee / spike2002 for the super cheap parts at such short notice!
^^ All top guys!
Looks smart mate, good work!
Awesome...
I know of a cheap ph2 xud turbo with decent engine if you want whole car??!
Keep it up...or sell it to me!!
Whats the future plans mate more epic boost?
Does look tidy got lot of love for the 205 Smile
Ahh the good old days of staying up 3 days straight, feeling ill from the burning oil fumes and several rescue missions a week haha.
Was a good summer of totally destroying cars half it's age though haha
Love it!!
Awesomeeee
Nice one Luke, looks quite OEM with the XUD9. Reckon your right foot would be more suited to a bigger turbo though!
Project thread!
Lot of love for this little car, almost a shame you've lost the fist-able arch gap.
Summer love >
[Image: TH-2013-07-16-CleeHill-8883_zpse36a0010.jpg]
[Image: TH-2013-07-16-CleeHill-8877_zps997b01bb.jpg]
Looks epic, miami blue is always a winner!
I've lots of plans for this car, I'm just sitting comfortably and collecting parts at the moment... I have a few custom things to be made and a lot of stuff to rebuild. I'm hoping to build it in time for FCS, should be a reasonable deadline given the amount of stuff I need to do. Time to pull my finger out!
Looks good should be fun when it's all finished
The paint on that looks amazing! Its my favourite colour too!
Is an epic little car sir hi.
Get it back on the road! Smile
Blaze '6 and Blaze D-turbo!
Very tidy Smile will be intresting once it is finished :-)
My k14 lasted 1 month at 30-32 psi Smile)
update needed tbh...
Team Cyril
(20-01-2015, 03:38 PM)Matt-Rallye Wrote: update needed tbh...
Indeed
Looks stunning considering it's age,what's it like underneath?
[Image: Cn91r40h.jpg]
Ah so you did put a thread up! I just somehow missed it for a year. lol
Yes, update required!
I hope the 3 fuckin minis were shown the door for more space for the 205!
(22-01-2015, 02:26 PM)procta Wrote: I hope the 3 fuckin minis were shown the door for more space for the 205!
Why? They're an undeniable classic and have serious value these days. No doubt if they were metro's you'd have had a crisis and we'd never hear the end of it in this thread Tongue lol
Wait procta has a metro!?!?!
nah id be the same Tongue, as you got to respect the 205 , after all its a better car isn't it.
(22-01-2015, 08:12 PM)Seb_Ryan Wrote: Wait procta has a metro!?!?!
rumour has it and there has been sightings of one on the drive way,
I didn't realise Luke still has this
Stripped too a bare shell i hear. awaiting rebuild.
Team Cyril
Ok, so this is a boring 'update'...
I do indeed still have the car and recently started the rebuild (2 years late!), mainly just welding and painting the bay so far, of which I have no pictures yet, but will do a proper update this weekend.
Here's the only picture I have to hand, better than no pics, I guess?
[Image: WP_20151002_15_07_53_Pro_zpsjaocttjc.jpg]
Haha good man! Love this little thing, great to see you've still got her, looking forward to the weekend.
It lives!
Love this little thing Smile
Look forward to the update!
Looks good, 205's are awesome Smile
  205 GTi6 Miami 306gtiparts 2 3,159 04-04-2015, 05:32 PM
Last Post: 306gtiparts
