26-08-2013, 12:07 PM
Wheres the Best place to get a new one and what sort or price am I looking at?
Top engine mount
26-08-2013, 12:28 PM
go to pug as aftermarket rubbers are not worth there money
so im told
26-08-2013, 07:52 PM
Whats wrong with yours?
I got some 2nd hand 1s if your interested?
26-08-2013, 07:55 PM
Think mines shot, want to replace the mount and chock it
26-08-2013, 08:09 PM
check for cracks before doing anything
27-08-2013, 05:25 PM
When I was changing mine I forget about the order of loosening, in results (after loose four of 6 probably) the engine dropped a few centimeters and stopped blocked at the two screws from engine side. I had to replace the nuts only, fortunately bolts in engine survived. Lift from bottom helped only a little
07-09-2013, 12:21 AM
Any tips for getting the mount out to inspect the cradle?
07-09-2013, 05:13 AM
We have the proper tool at work to undo the mount
07-09-2013, 06:34 AM
with engine in place is bloody tight.
but with the right tool and hammer, knock away at the low half, find a nice spot, there are some holes in it which a good drive punch/blunt chissel sits in, and knock it round to get it going. dropping engine as far as poss helps Wishes for more power...
Sorry to thread hijack, but I'm about to do similar and replace with a vibra technics mount just wondering if using a cut down buffer from my d turbo would work as a chock?
Oh and to get old mount out you'll need a chisel and hammer, you'll need to make a groove in the metal casing and then knock it round as if undoing a bolt/nut. I did this earlier to check mine as feared the worst, but luckily mines all good
PH1 FTMFW!
07-09-2013, 05:22 PM
Fairly sure the buffers are the same on all the xu engines.
I have a set of Peugeot sport group n buffers here left over from my s16
07-09-2013, 05:32 PM
Was going to cut it to make it fit, difficult to explain but I'll get some pics up of what I'm doing when I start it
PH1 FTMFW!
07-09-2013, 05:50 PM
| Top engine mount | Mighty306 | 6 | 5,765 |
12-10-2017, 03:24 PM Last Post: cully |
| Bottom engine mount fork bush | DeeTurbo | 5 | 3,392 |
08-07-2016, 10:24 PM Last Post: Jonny81191 |
| Lower engine mount | Niall | 12 | 5,457 |
22-10-2014, 10:14 PM Last Post: miles |
