Clutch pedal clicking noise/feel
My pedal makes a click noise and feel every now and again.
Is it the cable self adjusting or just getting caught on something do you think?
Seems to have a bit more play before the clutch starts to get hard when you press it since I first had it.
NO SMOKE NO POKEBig Grin
you took the spring off the clutch pedal?
(24-08-2013, 03:15 PM)Chris_90 Wrote: you took the spring off the clutch pedal?
no. should i
Yes.
It's likely f*cked and causing this problem. My clutch cable broke after mine did it.
(24-08-2013, 03:18 PM)bigcheez2k3 Wrote: Yes.
so this spring just pushes the pedal back up but if you take it out the disphram spring on the clutch bascicsly brings the pedal back up
Yep. It's meant to make the pedal easier, or something to that effect, but they get seized when old, or broken. There should be a thread floating about by cspellowe that has a load of info.
(24-08-2013, 03:30 PM)bigcheez2k3 Wrote: Yep. It's meant to make the pedal easier, or something to that effect, but they get seized when old, or broken. There should be a thread floating about by cspellowe that has a load of info.
Thanks ill try finding it.
Done[Image: eperu8u4.jpg]
It had a lot of grit stuck to it but was quite oily so my brothers dad who had it before me must of had the same problem and temporarily fixed it by greasing it up but then little bits of grit stuck to it.
Pedal feels a lot better now. Thanks
I just did mine. Way better stops the juddery way the pedal use to return.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Mine done this then the release bearing shat itself
  Relay Clicking paul7278 5 3,882 19-12-2013, 12:07 PM
Last Post: Chris_90
  Clicking noise and now wont turn over HDIkyle 5 3,737 17-08-2013, 10:01 AM
Last Post: Piggy
