Wanted: lower column uj for 205
As above, need a lower steering column uj for the 205. Its for a power steering rack and is flat drive I think. Cheers!
Same Sad
Oh dear haha, already decided i'm going to fab up a heatshield for it when I find on to put back in, should have had one as standard. Sad
I was lucky with mine £6 down scrappy, not easy to get though! Good luck
[Image: signiture.jpg]
I can get a whole column at the local scrappy for £30 but need to go and see what type it is, if it's the type you need ill let you know.
I have a flat driver fitment one if you want it, not sure if its a power steering one or if it really makes any difference or not ?
Power steering are different, I'm pretty sure
Yeah they are, there are 3 types; Ph1 PAS, Ph1/Ph1.5/Ph2 non PAS and ph1.5/2 PAS.
I may have one for sale depending if the cars getting broken or not.
Stage 2 XUD Sedan
Mine is in fact spline drive, blame niall lol. Think i've managed to source a replacement joint, as in the cross-piece with accompanying bearings, so hopefully as good as new for less than £40, failing that got plenty of options now, cheers guys! Big Grin
Yeh I remember now, splined is power steering, flat isn't.
Not sure if anyone's interested, but I ended up paying £28 for a new hardy spicer cross piece and took me a couple of hours to replace the old one, well worth doing imo considering the silly prices traders want for the whole shebang.
not bad pal. well done
I ended up cutting the original out and welding one from a 306 in. where did you get the new spicer?
Local bearing specialist ordered it in for me, 38mm x 16mm if anyone wamts to do the same.
  Wanted: 306 lower steering column shaft/joint 306clot 2 3,152 16-09-2015, 05:09 PM
Last Post: 306clot
  Steering column/ UJ's Tom 3 2,490 14-08-2013, 07:55 PM
Last Post: kernow_joe
  Steering column martyn92 8 5,770 23-04-2013, 05:58 PM
Last Post: Bertman
