Threads: 581
195
Drivers side ph3 3 door window motor wanted either collected or posted please
Threads: 581
195
Bump. Desperate seeing as i cant use my drivers window lol
Threads: 92
43
Car Model/Spec: Tracterrrrrrrrr
Ph1 the same? Im sure I have a pair of ph1 motors in the cupboard
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam
Threads: 581
195
Nah they arent. Plugs are different
Cheers anyway!
Threads: 20
6
I used a ph2 one in my ph1, or is it between ph2 and 3 they change?
Threads: 581
195
(18-08-2013, 10:18 PM)Stephen Wrote: I used a ph2 one in my ph1, or is it between ph2 and 3 they change?
Correct. Ive seen some where you can actually remove the plug from the motor and fit the one from your old motor then plug in the loom but ive also seen some that you cant so want to be sure i can plug it in lol
Threads: 20
6
Fair enough.
Has to be the right number of doors too, I made that mistake once
Threads: 124
26
Car Model/Spec: Megane DCiR
19-08-2013, 07:30 AM
(This post was last modified: 19-08-2013, 01:35 PM by CJ_Derv.)
I got one you want the runners and stuff complete? Not sure if my motor is separate or not but will send full lot
