When should I change brake fluid
So I've got some new front disks and pads to go on along with some DOT 5.1 fluid. While I'm fairly confident in changing the dicks and pads I have no idea with the fluid, I need to clean the lines or something? I dunno.
My question is, could I put on the new pads + discs now and then change the fluid later or is it something that should just be done at the same time?
[Image: mcetg0.png]
So you like changing dicks eh?
Serious comment is serious, changing the brake fluid just entails flushing the system through with new stuff. Easy as pie
Fluid will get darker the older it gets. New, its clear and has a slight straw colour to it. When it gets old, it will start to look like that morning after a heavy night piss. Thats when it needs changing. Just grab a few litres from halfords and bleed from the furthest to the closest to the MC. You want to keep bleeding until the fluid coming out is the same colour as the new fluid then move onto the next calliper and so on.
Id just do it anyway. You will be surprised at the difference it will make!
every 2yrs
Yea I got the new fluid 2 litres for 12 quid , should be enough.
So its okay to change to fluid at a later date to the pads abd disks?
[Image: mcetg0.png]
you can do the fluid anytime you like.
with 5.1 you will notice a nice difference
Cool, didn't realise thered be much difference in the two. Just thought itd last better against heavy abuse
[Image: mcetg0.png]
brake pedal feel is much improved
Tbh any 2nd hand car it'd be a good idea to flush the system and put new in you'd be surprised at how many dont have a 2 yearly flush
This is what I'd flushed out of the 306 the fronts were golden the back lines were black!
[Image: 50f5c238.jpg]
www.prestige-auto-care.co.uk
  Best brake fluid and pads? JTaylor2005 19 11,269 19-08-2016, 08:09 PM
Last Post: Pgtips
  ATE v Pagid dot 4 brake fluid 306rhys 1 3,190 28-08-2015, 10:08 AM
Last Post: PartyJas
  Brake fluid circulation hennus 5 3,815 12-03-2015, 10:49 PM
Last Post: Niall
