Threads: 12
Car Model/Spec: Peugeot 306 HDi Meridian
Hello again!
Car has developed a nasty rumble and vibration when the clutch is depressed. It is more pronounced when the clutch us down halfway (at least the vibration is) but is still present when the pedal is all the way down.
Any ideas?
Threads: 82
27
Sounds like the clutch release bearing tbh
Threads: 12
It's probably not as bad as I made out but it's definitely there. The diesel noise masks most of it!
Threads: 162
21
When mine went it bent my release fork as it went through the diaphragm spring and then part of the diaphragm spring took a chunk out the gearbox casing!
So I would say get it done sooner than later.
