Threads: 77
2
Car Model/Spec: 306 phase 1 bianca dturbo
Given 0 thank(s) in 0 post(s)
15-08-2013, 05:07 PM
Hi folks.
I'm new on here but I've read quite a bit already and the knowledge on here is unreal. Maybe I'll be able to pick a few brains and raid a few sheds as I turn my new love a 98 Diablo 306 1.9td lx 5dr mule into a racehorse.
I work in a huge car supermarket in Derbyshire and sell and see really new cars all day. They are so soulless. I love my 306. It's a tryer, a fighter. I love it.
So, it has a Lucas pump and a T2. I've done the stage 1 tune and popped a decat on there and I'm now at 18psi with the wastegate fully open and boost controlled by the fuelling. I get a nice haze on full boost and no smoke. I don't really want the smokey look. As I burn past I don't want them thinking its about to blow up! I got some front gti6 shocks and lowered it 40mm, back end to be lowered to match very soon. gti6 front brakes also added. 2 sets of cyclones but I've seen some Mi-16s and I might not be able to resist them.
I now feel that the car is being held back by the pump, and I may aswell go for a bigger turbo at the same time as putting the Bosch pump on. I like the way the T2 spools up, especially since the decat went on now at peak boost at about 2.2k so I'm shying away from the TD04 as they need revving hard right? So my 1st question would be which sounds the better option turbo out of the T25 or GT2052s (are they both bolt ons?) and second question 9mm or 11mm pump?
Any advice appreciated.
Nice to meet you all. PC.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Threads: 170
5
Car Model/Spec: xud 1.9 dturbo
15-08-2013, 05:11 PM
(This post was last modified: 15-08-2013, 05:12 PM by karl1989.)
Welcome along. Get a project thread up. I'm running a T25 with no filter sounds epic
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 289
92
Car Model/Spec: Phase 17 R26
Welcome to the club! Good to see you're finding lots of information on here so far, keep reading and you'll have the car setup very well and pushing big power in no time!
Threads: 581
195
Given 81 thank(s) in 77 post(s)
Welcome. There is plenty of knowledgeable people on here when it comes to these old dervs. Your in the right place for any help!
Threads: 448
51
Welcome along mate
Threads: 27
8
Car Model/Spec: PEUGEOT 308 FELINE
Given 5 thank(s) in 5 post(s)
Threads: 25
0
Welcome! Glad to see another member with a 5DR! and diesel!
Where abouts in Derbyshire do you work?
Threads: 77
2
(15-08-2013, 05:39 PM)MarkTD Wrote: Welcome! Glad to see another member with a 5DR! and diesel!
Castle donington bud.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Threads: 77
2
(15-08-2013, 05:11 PM)karl1989 Wrote: Welcome along. Get a project thread up. I'm running a T25 with no filter sounds epic
How does the T25 feel? Not read too much about those.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Given 31 thank(s) in 31 post(s)
15-08-2013, 07:26 PM
(This post was last modified: 15-08-2013, 07:26 PM by zx_volcane.)
Welcome
If you want simples, TD04 has to be the one
You can pick up ready made adaptor plates + a turbo for cheap and you're away. They're completely and utterly drivable, and when you get on full chat they pull like a train.
If you're a bit handy and don't mind making up some plates, crack on with a newer turbo, look out for anything on a modern-ish diesel running the kind of power you're looking for.
They'll be a bit more expensive, but have a look around and see what you can pick up - you might be surprised.
T25 is pretty old tech nowadays tbh
Grab yourself an 11mm pump for sure! Teddy has one for sale atm
Threads: 31
7
Car Model/Spec: 306 Rallye
Welcome
Almost every derv on here Smokes mate, i think they like sticking to the Quote: 'No Smoke No Poke'!
Threads: 198
135
(15-08-2013, 07:29 PM)Rich306 Wrote: Welcome
Well thats a lie. If it's smoking you need a bigger turbo. No smoke = m0ar poke
Threads: 122
9
Car Model/Spec: Kingfisher Ph1 Dturbo S
Given 7 thank(s) in 7 post(s)
(15-08-2013, 07:31 PM)cwspellowe Wrote: (15-08-2013, 07:29 PM)Rich306 Wrote: Welcome
Yours definitely smokes we all saw it whilst taking the fcs clubstand photo...
Threads: 9
Car Model/Spec: Diablo 6
Threads: 169
91
Car Model/Spec: 2003 Jaguar S-Type Sport 3.0V6
Given 1 thank(s) in 1 post(s)
Welcome to the mad house
Threads: 591
54
Threads: 96
7
Car Model/Spec: 306 tractor
Hello fella and welcome, where's mr lobb with all this talk about derv and powaaaaa !!!
Threads: 202
58
Given 29 thank(s) in 28 post(s)
Welcome along!
Get a newer turbo on there, look at the GT series turbos or even consider a VNT.
Threads: 77
2
Thanks for the welcome chaps.
I'm thinking I want a 9mm Bosch and after more reading I'm going to give the TD04 a bash 1st as so many use it. (Can't all be wrong) I'm just taking things steady to start hence the 9mm. Want to make sure the motor will take the extra revs. Can a 9mm be upgraded to 11mm at a later stage or is it a pump swap? I doubt ill need to though as i don't need it to be as powerful as possible I just want to make it a good daily hoonmobile. I think it's nippy now so can't wait till I've got the bits on it. I'm going to the parts section now and then Ebay to see what I can find!
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Threads: 2
Car Model/Spec: 306 GTI-6
Threads: 591
54
your 9mm pump can be rebuilt yes into a 11mm.
theres a td04 with all plates and mani for sale in the for sale section by the way..And I have bosch pump lines and injectors at end of month
Threads: 77
2
I can't reply to the parts section? Is it because I'm ginger?
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Threads: 591
54
you need 10posts.
have a look at some projects, leave some nice comments, get your count up
Threads: 117
21
Car Model/Spec: needs bwarrrp.
Welcome along mate. Im in derby myself so will keep a eye out for ya.
Threads: 96
7
(17-08-2013, 08:08 AM)Piggy Wrote: And I have bosch pump lines and injectors at end of month
Do you
Threads: 591
54
I do. a 9mm and a 11mm setup probably
Threads: 77
2
(17-08-2013, 07:49 PM)kingy Wrote: Welcome along mate. Im in derby myself so will keep a eye out for ya.
Where abouts in derby mate? I'm west Hallam.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Threads: 117
21
(18-08-2013, 02:44 PM)306pc Wrote: (17-08-2013, 07:49 PM)kingy Wrote: Welcome along mate. Im in derby myself so will keep a eye out for ya.
Alvaston or littleover when im arguing with the mrs lol.
Have a look in the meet section theirs a couple coming up. Always good to meet newfaces and get the numbers up.
Threads: 183
20
Car Model/Spec: moonstone hdi #2
Given 8 thank(s) in 8 post(s)
Yes we have a meet coming up at mfn night club in shipley/eastwood.
Im from eastwood inbetween Nottingham and derby. Will be good to see new faces.
I think nottspug might be around hes very local to me. Theres a few around notts derby.
Welcome to the club.
Threads: 77
2
(18-08-2013, 04:52 PM)kentiiboii Wrote: Yes we have a meet coming up at mfn night club in shipley/eastwood.
Welcome to the club. Hi, I used to live in newthorpe mate.know the area well.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
