Bearing number?
anyone have the bearing number fo the long driveshaft intermediate bearing?
please
just take the old one off and measure it?
yes easy answers are best
but i want to replace it once i strip it out not just to get the number and go get it
surprised you dont have a spare. Most 306 owners have at least 1 replacement for every part on the car Tongue
may lay up the 6 as the tax is due then do a big list
shaft bearing
shaft gearbox seals
sump gasket
mains cap rubber seals
may even put a set of new crank big end shells
These never did have a sump gasket. Was RTV out of the factory.
Good luck dropping the sump though. Ive never done it on a 6 but im pretty sure 2 of the bolts are behind the bell housing.
