Front suspension guider
Sorry dont know what's its actually called but here goes. Tried to adjust my coilovers today and the metal guider on the shocker that goes in the hub has decided to snap off causing the shocker to spin in the hub. Will this affect the car in anyway? I will get a new piece welded on but just thought I'd ask so I know not to drive it
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
It's not a good thing really wouldn't want to be the one who decides if its safe or not
Team Doesn't own a 306
Ask dumdum... Popcorn
Its not the turning you need to worry about, if you hit a hard bump the shock will drop though the hub hitting the drive shaft , making for a pretty big mess,
Oh and welding the shock............ just make sure it doesn't explode with the heat ThumbsUp
It's still got the bit on metal to stop it dropping down just not the point that drops in the hub
Ph3 perv cab heaven
Black ph1 XUD died
  Front top spring suspension Welshy_Pete 4 3,598 21-04-2018, 09:52 PM
Last Post: Mighty306
  front suspension johnnygomez 5 3,650 10-12-2016, 12:36 PM
Last Post: johnnygomez
  fitting a front suspension ball joint impotentials 3 3,680 29-10-2016, 05:46 PM
