xsi gear stick shaft replacement help
hi i used to own a 306 xsi 8v fantastic car.
now Ive got a 2000 xsi its ace but the previous owner cut the gear stick in half (not sure why but its annoying).
can you just replace the shaft or do you have to change the whole thing.
cheers Smile
Unbolts at the bottom. To see how to remove it search for the guide to fit a quick shift. Niall wrote an awesome guide an he explains how to remove. Then instead of fitting the quick shift just fit a new shaft
Easiest to change the whole thing rather than just the shaft. 4 nuts inside the car (under the leather gear cover) and one long bolt underneath attaches it to the linkage.
cool cheers
  Gear stick doesnt return to centre Lolben91 6 3,656 11-05-2015, 11:51 PM
Last Post: Lolben91
  Installing GTI6 gear stick - Cable too tight not 6th. Eeyore 10 6,596 02-12-2014, 01:11 PM
Last Post: welshpug
  Movement in gear stick. kentiiboii 11 6,391 29-05-2014, 02:36 PM
Last Post: kentiiboii
