hi and help
hi and help
hi im in neet of some help i'v got a 1.0 turbo derv 405 ive just done the head gasket water pump and timeing belt kit i'v done over 1000 miels since i did them and the cars been spot on but went to start the car last night and there was a nock the car now sturs over but the only seems to b compression on 1 cyinded and ext is comimg from the inlet ive have checked the timing and everthing lines up the only thing ive done is i changed the cam box gasket then it did this ive checked the cam carryers where the cam box bolts to and there is nothing rong
tar
tom
Welcome Smile
I can't read much sense of that I'm afraid.
Stick some punctuation in an try again Wink
Welcome
Welcome along mate.
Try posting your issue in the XUD section (I'm assuming you meant 1.9 TD) and maybe split your post into sentences to make it a little easier to understand.
