blue and white smoke on pull away
hi
ive been running a TD04 for a while, it started to throw out a bit blue smoke when it came on to boost, so i got any TD04 from ebay and this done the same maybe to a worse extent and filled my TMIC with oil (i think the ebay turbo was already f**ked)
so ive put my known good T2 back on and the blue smoke is still there??
the smoke an is really bad then pulling away through 1st and 2nd but clears up to almost nothing thrashing it thought the other gears.
any body got any ideas, i was thinking maybe stem seals or a snapped piston ring but really am i bit stuck
also there are no signs and headgasket failure
cheers
306 XUD9 gt2052s
306 hdi stage 2 (hdi tuning)
205 STDT -new project
That sounds bad, cant really help with what it might be, i would of said turbo but if you've ruled that out it might well be more serious Sad
compression test, to see if its oil, but could be diesel if the timings wrong, blue smoke could be diesel not burning properly
U sure its not just burning the excess oil out the boost pipes
EDIT: just seen the date for this lol
[Image: av5ym8.jpg]
  Xud9 White smoke and primer wont stay hard Donny165 5 5,675 13-07-2020, 12:22 AM
Last Post: ekjdm14
Sad Blue Smoke KilianManning 10 8,011 28-09-2015, 11:44 AM
Last Post: KilianManning
  Any descent mechanics blue smoke? blinkyeatu 22 12,083 31-08-2015, 06:44 PM
Last Post: blinkyeatu
