Rust! But wait.. theres more!
07-08-2013, 09:05 PM
Scrap it.....
My advice probably isn't welcome.
Thinking of having a go at repairing it but dont really have much patience for the car at the moment especially with having to fit new piston rings aswell. Thinking of buying another car and fix this one up slowly
If it's got a few issues why not buy a better one (doesn't sound like you could buy a much worse one lol
) and keep the best bits off yours to swap?Btw, you probably want to check your rear arch for rust if you haven't already....
07-08-2013, 09:57 PM
It has four arch covers thankfully! I Haven't actually checked the rear quarter but with the liner it should be alright. The plan is to possibly get another for the time being
07-08-2013, 10:09 PM
That will t cut out that lol...i thought the mot.ers wernt allowd to poke and prod..
(msg sent from hell)
07-08-2013, 10:18 PM
Fair enough martyn, just seems easier to get another to keep instead of stop gap.
![]() John, Mot man has a plastic hammer he is allowed to poke with lol....
08-08-2013, 06:06 AM
and thats why we dont jack up and put axle stands on the chassis rails!
08-08-2013, 08:18 AM
(07-08-2013, 10:18 PM)Toms306 Wrote: Fair enough martyn, just seems easier to get another to keep instead of stop gap. Shit he best not use it on mine one tap and everything will fall off i recon lol..
I had the same yesterday with my MOT inside the drivers wheel arch near the footwell big hole size of a fist... welded a plate in though
09-08-2013, 06:23 PM
Whereabouts in Preston are you? I'm from Penwortham originally.
HDi Owner for 200k/9 years
09-08-2013, 08:37 PM
Martyn, bring the car to me and we'll fix that in a few hours. I expect a banana and a pint in return!
09-08-2013, 09:18 PM
12-08-2013, 03:18 PM
Although it's nasty in that spot it doesn't look like it's traveled far. Metal looks good around it. Repaired and sealed that should last for years. Definitely not a reason to scrap it.
13-08-2013, 02:42 PM
Once you have all the grot cut out it's well worth putting a coat of weld through zinc primer over all the areas you can see as you'll have unprotected edges where you've made the cuts that will start to rust again with condensation. It's well worth a light coat on the back of all repair patches to help slow down any future rust. You can get cavity wax in aerosols too that you can spray in through any access holes you an find. It can seem like a waste of money at the time since you can't see it but in a couple of years time the repair should still be near perfect.
13-08-2013, 07:35 PM
Ouch! My holes on the chassis weren't that bad!! spray a shit load of Wax Sealant to kill the rust further down the chassis rail as well before welding back up!
Black mask Service
13-08-2013, 09:21 PM
13-08-2013, 09:28 PM
Protects the car from it, and i'm sure i read on one of the particular cans it kills it.
But i've already proved my memory is shit.. Read up on this: Waxoyl good? I Black mask Crystal headlights, check out my Thread
Black mask Service
14-08-2013, 05:10 PM
Waxoyl certainly helps keep rust at bay (and claims to kill old rust) but just remember that it goes on fire really easily so if you spray it in before you weld the repair things could get exciting!
15-08-2013, 11:41 PM
(This post was last modified: 15-08-2013, 11:44 PM by bigtone0777.)
http://www.hammerite-automotive.com/waxoyl.htm
Wow I didn't realise that it kills existing rust just knew it protected the metalwork from the elements. I def want my car coated but have to prepare myself for the smell again first lol
16-08-2013, 05:28 AM
I thought i wasn't losing my mind lol, thanks for confirming it for me!!
Black mask Service
16-08-2013, 12:03 PM
16-08-2013, 12:39 PM
(07-08-2013, 09:23 PM)Matt Wrote: Big f*ck off splatter of weld! Done It's a spatter of weld. a spatter refers to something else....
Astor 'X' 4 GTi6-6 - SOLD! ![]() '08 LY Renault Megane RS 230 F1 Team R26 - GONE '56 BMW Z4 Coupe 3.0si Sport - SCHWIIIING!
16-08-2013, 02:46 PM
I served my time as a welder on marine equipment and after welding we always applied a coat of vactan rust treatment, works really well and can be bought from eBay quite cheaply.....
If you have any problems getting it welded let me know and I can sort it for you... Also have some vactan here..... Jamie
16-08-2013, 07:53 PM
I think I should hopefully have it sorted soon! just waiting for a day off with good weather to finish off the welding
19-08-2013, 12:18 PM
I would of scrapped it, so fair play to you
| Rust conversion treatments / gel | Mighty306 | 6 | 5,856 |
31-05-2018, 01:46 PM Last Post: pug306driver |
| Rust Treatment | MY95 | 4 | 4,316 |
25-11-2016, 08:07 PM Last Post: pug306driver |
| Roof rust | DM123 | 11 | 5,891 |
08-05-2016, 09:14 PM Last Post: insomaniac45 |
![[Image: 20130807_120537_zpsaa31c3d9.jpg]](http://i799.photobucket.com/albums/yy275/martyn992/20130807_120537_zpsaa31c3d9.jpg)
![[Image: 20130807_141108_zpsb057a2ff.jpg]](http://i799.photobucket.com/albums/yy275/martyn992/20130807_141108_zpsb057a2ff.jpg)
![[Image: 20130807_141125_zps8de8cbdc.jpg]](http://i799.photobucket.com/albums/yy275/martyn992/20130807_141125_zps8de8cbdc.jpg)
![[Image: 65613_10200761612710317_1548698655_n_zps68c27004.jpg]](http://i799.photobucket.com/albums/yy275/martyn992/65613_10200761612710317_1548698655_n_zps68c27004.jpg)
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg)
Heres a few more pics from today removing a little more underseal/rust... ![[Image: 20130809_184515_zpsbc00745e.jpg]](http://i799.photobucket.com/albums/yy275/martyn992/20130809_184515_zpsbc00745e.jpg)
![[Image: 20130809_184740_zpsb407d40f.jpg]](http://i799.photobucket.com/albums/yy275/martyn992/20130809_184740_zpsb407d40f.jpg)
Hopefully going to try get it sorted tomorrow if I can! ![[Image: 20130812_154059_zps5f2ffdff.jpg]](http://i799.photobucket.com/albums/yy275/martyn992/20130812_154059_zps5f2ffdff.jpg)
