A bung
Or sensor. What ever goes in the hole on the rad.
Where the top hose comes from, I have a black bolt shaped screw in bung. I'm guessing its normally a sensor? Either way I need either a bung or a sensor, as somehow mine started spraying water. I touched it with a spanner and it fell off. Looks like the thread snapped.
So need one posted too me ASAP!
If you have a sensor I don't care if its broken, just need the hole plugged!
Help a brother out! Smile
You talking about the bleed screw on the top of the rad, or the sensor that kinda goes in the side at the end of the rad?
Either way I have neither
Haha the sensor under the top rad hose. Or it could be a bleed point. Either way it's directly under the top rad hose
Ahh, if it's under the hose then yeah it's a sensor. I thought you meant the fiddly black screw on the top of the rad.
Nah for some reason mine doesn't have one lol
I have the bung nut thingy ma bob, if you still need one
Team Doesn't own a 306
Yeah man, can you get a pic? Want to see if mine has snapped a lot or not
Ill get one tomorrow when I'm down unit pal Smile
Sweet cheers man
  Wanted: Resinator bung gti6 sherman306 8 3,711 22-07-2014, 12:34 PM
Last Post: sherman306
  Rear wiper bung! W1ll 8 4,822 17-04-2014, 08:44 PM
Last Post: bigcheez2k3
  Wanted: GTi6 Manifold & de-resonator bung, de-cat. Carlos182 1 2,033 09-09-2013, 10:57 PM
Last Post: ginge191
