help with fans not working.
Hi all. Recent trip to the alps in the hdi and with a few traffic jams it became apparent that both fans arent working.
I can work my way around the rallye engine bay not a problem but the hdi is a different ball game. Relays appear ok. Can only fine one sensor a 3 pin one which gibe the dash reading. Thats ok and not sure if there is another that controls the fans.
Any help?
Have you tried a live feed direct to the fans? Will tell you whether or not it's the motors at fault. There's also a round screw-on connection behind the ecu which the fan controls pass through, maybe worth checking there for corrosion.
