starter duff??
starter duff??
hi guys i think my starter is playing up the wire from starter to battery gets realy hot causing battery to get green stuff on... today i went to start it and when on 2nd click it had a high pitch screem and speedo goes to 140 i tried bumping it a little but was rolling enough but after that it started but stopped and it was fine for another 2 starts then stopped again and did the same so i let it roll in 1 then took it out off gear and it started straight away
Sounds like that wire getting hot is either f*cked or to small. Or your battery terminals are shit. Check all terminals all earths and all the terminals and wires on the starter aswell.
my mate thought it could be cause the solinoid sticking as i used to get it click then start fine i will check all wires thou and clean them up
