EGT Probe Positions and Drill bit size
Ive seen a thread on here before about egt probe positions but cant seem to find it again! Where is a good position to tap a egt probe on a T2 mani/ td04
Also what drill size is used for the 1/8 tap? (11/32 5/16 or just a 8mm?)
I drilled it at the bottom of the manifold on the curvy bit.
Not sure on drill bit size, i just went up the sizes til it felt like the right size to start threading it.
IIRC I used an 8mm bit and its been fine. You want the tip as close to the centre of the turbine inlet as possible.
  Lucas pump timing probe issues weka 0 2,856 21-03-2019, 08:39 PM
Last Post: weka
  Top mount intercooler bolt size/ timing hole size LewisG306 2 3,126 13-07-2014, 10:44 AM
Last Post: LewisG306
  EGT Probe Location silverzx 14 9,142 05-08-2013, 05:16 PM
Last Post: Frosty
